20 Most Recent Lewmar Pro Series 700H Horizontal SS Windlass Questions & Answers
Pins are splayed on the end to keep them from coming out. Remove entire hinge or drill out pin and replace, remembering to peen the end again.
Lewmar Boating | Answered on Sep 12, 2017
Need to strip it down and check the motor or any seized parts.
Also check that you have a return as well as a live feed. IIRC, there is one live and two returns, one for up and one for down.
Google the model number and the words 'parts schematic'.
Boating | Answered 3 days ago
When I worked boats years ago. We had a brand new boat gettin water in it. Finally found that the bell housing had a porrous casting in it allowing water to seap in from the exhaust port.
Boating | Answered on Apr 17, 2019
ALWAYS BY THE MACHINE OPERATOR AND NORMALLY IN THE SHIFT CONTROL BOX OR DASH BOARD
Boating | Answered on Apr 12, 2019
specifically or in general? Now single system depth finders are pretty rare as you know have GPS and Fish Finder properties and also plotters that will automatically steer the boat to destination. I have a Humminbird 998 with Side Imaging and all in HD. Side Imaging gives a 3D image of the bottom structure and objects.
Fishing Sonars, Fish Depth Finders & Chartplotters ' SAIL
https://www.sail.ca/en/fishing/sonars
  1. Cached
LOWRANCE HOOK² 7 Fishfinder with SplitShot Transducer and US / Canada Nav+ Maps. ... HUMMINBIRD HELIX 5 CHIRP GPS G2 With Navionics Card. ... HUMMINBIRD Helix 5 CHIRP DI GPS G2 Sonar With Navionics SD Card.
https://www.google.com/search?q=Depth+finder&sourceid=ie7&rls=com.microsoft:en-US:IE-ContextMenu&ie=&oe=
Boating | Answered on Apr 11, 2019
There is no fuse box, they use inline fuses. Chase the wiring back to the battery, somewhere near the battery or the radio/fish finder will be a fuse on the power wire.
Boating | Answered on Apr 09, 2019
Check for a loose connection or corrosion at the transducer and the unit. Less likely, but bent or broken pin on the connector at the back of the unit. It always works until it doesn't, so that information is of no use.
Boating | Answered on Mar 30, 2019
THEN YOU BOUGHT THE WRONG ITEM . WE KNOW OF NO FIX
Boating | Answered on Mar 29, 2019
Lewmar Pro Series 700H Horizontal SS Windlass Logo
1 questions posted
Top Lewmar Boating Experts
ray gallant
ray gallant
Andrew Taylor
Andrew Taylor
Tom Chichester
Are you a Lewmar Boating Expert? Answer questions, earn points and help others
View Most Popular
Lewmar Boating
  • Lewmar Boating
Most Popular Question
during hauling in operation windlass
  • Boating
