20 Most Recent
GE GMR02BAN Compact Refrigerator Questions & Answers
Compact Refrigerator stop cooling, I am out of ideas.
Good day,
If you hear the compressor running, then the overload and relay are O.K. It can be one of three things.
1. Leak developed in system.
2. Restriction internal in the refrigerator sealed system.
3. Valves in compressor failed, which would not provide any pumping action for the refrigerant.
None of these items are practical repairs on a compact. But if it's under warranty (under 5 years old), check with the selling dealer for warranty claim.
P.S. Does not apply if coils were punctured.
Thank you for using FixYa
Why internal lights not working yet panel lights do?
There could be several reasons why the internal lights in a vehicle may not be working while the panel lights are functioning. Here are a few possible explanations:
1. Blown fuse: Check the fuse box to see if the fuse for the interior lights has blown. If it has, replace it with a new one of the same rating.
2. Faulty light switch: The switch that controls the interior lights may be faulty or worn out. Try toggling the switch on and off to see if it makes any difference. If not, consider replacing the switch.
3. Loose or corroded wiring: Inspect the wiring connections for the interior lights. Loose or corroded connections can disrupt the electrical flow and prevent the lights from working. Tighten any loose connections or clean off any corrosion.
4. Burnt-out bulbs: If all the interior lights are not working, it's possible that multiple bulbs have burnt out at the same time. Check the bulbs and replace any that are no longer functional.
5. Dimmer switch settings: Some vehicles have a dimmer switch that controls the brightness of the interior lights. Make sure the dimmer switch is not turned all the way down or set to a very low level.
If none of these solutions resolve the issue, it may be best to consult a professional mechanic or electrician to diagnose and repair the problem.
