20 Most Recent
GE JKP27 Electric Double Oven Questions & Answers
Error code F7 keeps coming up, what does this
F1 error and beeping. Don't bother getting GE out there. Cost me $90 to learn they don't make the clock. WOuld have been $500+ for the control panel anyway. Better off just buying a new one. Planned obsolescence I guess. I won't buy GE again.
7/8/2018 6:12:00 PM •
GE JKP27...
Answered
on Jul 08, 2018
Probe and sensors sticking too far out
Yes the probes can stick out from the back oven walls. They look like thin pencils about 6" long. They should NOT be loose. The probes are your temperature sensors. If they become damaged your oven may not work. The probes are generally high up on the wall and to one side...about an inch or so down from the top...and the same from the side. They should be horizontal and not bent at an angle. Some probes run along the side of the oven wall and do not protrude into the baking area. In general the probes (whatever type) should not really interfere with the baking zone
10/21/2017 6:26:39 PM •
GE JKP27...
Answered
on Oct 21, 2017
Oven heats up, but then turns off
either bad igniter or bad oven safety valve check with multi meter. for continuity. beware that the igniter can check ok with multi meter but still fail manually as it may not put out enough current to run heat and ignite flame. u may also have a bad oven sensor? which turns off heat prematurely agin check with multi meter
3/11/2015 10:27:16 PM •
GE JKP27...
Answered
on Mar 11, 2015
GE model # jkp27 error
Hi ssantillo,
Usually F1 error code means that either the touch pad or the oven control (also called clock or ERC) is defective and needs to be replaced. If this fault code cannot be cancelled, replace the oven control (also called clock or ERC), touch pad, or both.
Hope this helps.
Thank you for using FixYa.
3/20/2013 9:25:55 PM •
GE JKP27...
Answered
on Mar 20, 2013
GE Double Oven Controller WB27T10276 Connection Details
I successfully replaced my WB27T10063 with the WB27T10276 (ERC3-GE-M) by following the instructions (Pub. No. 31-10515)."they tell you for the Broil Relay to connect L1A to the common terminal."This is simply a misreading of the poorly written instructions.
- Bake: yellow goes to yellow NO.
- Broil: violet goes to violet NO.
- Broil: black L1B goes to violet COM.
- AUX 2 goes to AUX2 (black and white wire).
- AUX1 goes to AUX1 (daisy-chained black from violet COM/L1B).
- OV2 goes to OV2 (white wire).
- OV1 goes to OV1 (brown wire).
- L1A goes to L1A (daisy-chained black from AUX1).
- N goes to N (daisy-chained white from OV2).
- GND needs to be "tucked under the (steel) clock bracket" on the control panel.
The hardest part was disconnecting the wires from the old ERC. Took a LOT of force! I also had a hard time figuring out how to release the green tape thing apparently labeled "J1" on the old ERC. Piece of cake after that.
2/16/2013 3:44:05 AM •
GE JKP27...
Answered
on Feb 16, 2013
My GE double oven is flashing F1 and beeping
The F1 error is similar to the F7 error and the fix may be similar. It indicates that the touchpanel needs to be replaced. The problem is really one where the insulation is breaking down between two sections of the ribbon cable which connects the touchpanel to the electronic control. I have solved the problem by placing slip of paper between the two secions of the ribbon cable. The slip of paper should be worked down into the slot. It will only go about 1/8". A piece of file card material works well. See attachec photo. If you have a metal touchpanel, you will also have to add slips of paper at the edges of the metal slot.
__Be sure and turn off the power to the oven at your circuit breaker!____There are usually three small screws at the bottom of the touchpanel. The panel may need to be pushed upward to release it. Have a friend available to hold the panel while you work on it. Do not allow the panel to dangle by the wires.____Please let me know if this works for you or if you have any questions. You can reach me at
[email protected]. I have shared this solution with over 830 folks. Most report success.
12/7/2012 1:16:49 AM •
GE JKP27...
Answered
on Dec 07, 2012
