20 Most Recent
GE JRP24 Electric Double Oven Questions & Answers
Jrp24bow3bb electric double oven control panel.
Hi rhonm,
You should have found a connection diagram in the top of the oven. If you didn't, call GE at the following number and they will send you one. 1-800-626-2005
It would be very difficult for any one to make a recommendation without seeing the oven or part. Are there one or two gray wires? My first guess is that they sent you the wrong part. See photo for typical double oven ERC.
Regards,
Powerman
6/15/2022 7:48:32 PM •
GE JRP24...
Answered
on Jun 15, 2022
Heating element disconnected
Make sure to keep breaker to oven off because wire could short against back of oven and start a fire. You need to disconnect the tilt bracket and pull the oven out. Replace the clip on the wire if needed. Make sure to reattach tightly. Put it back in the wall, reattaching anti-tip bracket. It should work.
6/4/2014 12:56:00 PM •
GE JRP24...
Answered
on Jun 04, 2014
Tried to do self cleaning
Error code F2 on clean cycle is indicating that the maximum permissable cleaning temperature has been exceeded. (or it's got too hot!)
However it seems unlikely that that would happen in just 10 mins. more likely it is a problem with the oven temperature sensor which should be checked over as should the lock switches..
7/19/2013 7:48:42 PM •
GE JRP24...
Answered
on Jul 19, 2013
Jrp24bod1bb GE Double Oven
you would need a minimum of 48&1/8" high,23&1/2" Deep, and 22&1/2" wide and 14" off the floor for ventilation per G.E quick specs
2/25/2013 1:11:01 PM •
GE JRP24...
Answered
on Feb 25, 2013
My GE top double oven
Hello, Thank You for using FixYa. I will be helping you today.Sounds like a shorted key. Turn the power off. Unplug the ribbon cable from the control turn the power on and see it it keeps doing it..If it stops replace the touch membrane.
Thank You and please rate my answer if it was helpful..
6/20/2011 12:21:22 PM •
GE JRP24...
Answered
on Jun 20, 2011
Double wall oven broiler goes
it could be the touch panel or the computer board,the model number you gave isn't the full model number like 10 different models came up,next time get the number off of the machine not the book,if this is a newer machine you can push the clear/off pad, unplug the touch panel ribbon for a minute or two,if the code comes back it's the computer board,if it doesn't come back it's the touch panel.he must have pulled out the tech sheet and showed you what it said for an f7 error code and if he said it's the panel he must have done this test.
4/18/2011 6:56:53 PM •
GE JRP24...
Answered
on Apr 18, 2011
Oven element will not come on but broiler works
There are three possible defects to conside. In order of likelihood given what you've described...
1) The bake element is defective. You can remove it and check it with an ohm meter. A good one would be roughly 20 to 40 ohms, a bad element has high (or very high) resistance.
2) The oven thermostat. It controls both the bake and broil elements, but has seperate control circuits (contacts) for each. The bake element is used most and most likely to fail. You *can* check for voltage while its operating, but if you aren't sure of what you're doing its an unnecessary danger. If you eliminate the element (#1 above) and the wiring (#3 below) then the thermostat is what you have to replace.
3) The wiring from the thermostat to the bake element could be defective. (I'm sorry, I don't know if your bake element has a socket or just wiring. It is possible for a bad socket to burn and pit the element's contacts and to have to replace both.). This is the least common cause, but if you test the bake element resistance at the thermostat, that includes the wiring, and if the element by itself is good, but not with the wiring then its the wiring. Since the broil element works, the wiring feeding power to the thermostat is good, and the only wiring to check was from the thermostat to the bake element.
12/31/2010 4:18:53 PM •
GE JRP24...
Answered
on Dec 31, 2010
I have a jrp24bod1bb but that model number doesn't
Hello- The oven control (computer/clock) is available thru applianceparts.com and repairclinic.com for about 120$. The control panel is about 250$. Make sure on-site diagnostics confirm which one before replacing. Let me know if this info helps- have more if needed. Thanks- Ed
3/17/2010 6:00:48 AM •
GE JRP24...
Answered
on Mar 17, 2010
Replacement Element does not work
If it is a double circuit element, then you will only get 110 vlolts across one circuit, and 220 volts across the other circuit..
If however it is a single circuit element, and you are only getting 110 volts, then I would suggest that you have a high resistance somewhere that is stoping it from getting 220 volts.
Hook the element directly to a 220volt supply and check voltage .
Plz rate my solution.
Thanks.
12/17/2008 8:39:15 AM •
GE JRP24...
Answered
on Dec 17, 2008
Bottem Oven Over Heats
GE announced a recall for some of its wall ovens this week for an overheating problem. Have you contacted a GE dealer yet?
11/20/2008 4:56:36 PM •
GE JRP24...
Answered
on Nov 20, 2008
