20 Most Recent
GE JKP85 Electric Double Oven Questions & Answers
GE microwave model: JTP85W0A2WW is
You should check the transformer that giving the supply to the motor of your turntable but it is dangerous to handle if you are not familiar with microwave ovens because microwave oven uses a high frequency signal. Or try to test the magnetron But be sure to unplug the unit. Discharge the capacitor of your microwave oven by using a screw driver then slowly slide the screw driver to the chassis of the microwave oven you should hear a popping noise. Then you should use the screw driver at the same manner to short circuit the capacitor terminal to discharge the current in the capacitor. Then try to identify the magnetron, then you should put a level on each wire to be sure the proper location of each terminal then you should touch the test probe of your tester in both terminal. Set the multimeter to the lowest resistance scale. Each probe should be touching the terminal, you should have a reading of less than 1 ohm. Or try to consult a technician to do it for you and save you from stress.
9/10/2011 6:59:06 AM •
GE JKP85...
Answered
on Sep 10, 2011
No heat and no rotate of the turn table.
Welcome to fixya
Hello
I have a solution for this
Press Ok, Accept or replay so we may get started
Your pre-solution is coming up shortly
PLEASE REPLY OR LEAVE COMMENT TO CONFIRM YOU RECEIVED THIS EMAIL
1/16/2011 9:10:57 PM •
GE JKP85...
Answered
on Jan 16, 2011
My GE gas oven
The safety solenoid on the gas valve has failed.
This is not a repair you should do (other than remove the gas valve) let the appliance repairman rebuild the valve and check for leaks.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
9/6/2010 1:31:02 AM •
GE JKP85...
Answered
on Sep 06, 2010
I have a burned out microwave light bulb
if its an over the range one remove the vent at top you should be able to acess it from there if not remove the mw remember to unplug unit either way most will blow the board if changed while power is on
5/27/2010 5:53:24 AM •
GE JKP85...
Answered
on May 27, 2010
Microwave display just flashed F6 error code. Only
To allow us to help you effectively (at no charge), please post a NEW problem to FixYa, and please
include your brand name and the full model number from the tag in or on
the unit, and remind us that it displayed an F6 error code.
11/26/2009 11:40:18 PM •
GE JKP85...
Answered
on Nov 26, 2009
