20 Most Recent
GE Monogram® ZET958 Electric Double Oven Questions & Answers
My oven had flames burning
The oven wont unlock until the inside is at a certain temperature, to prevent you from burning yourself with the convective heat, or worse, the fire spreading to outside the oven. Once the flame runs out of oxygen inside, the flames will go out. But the oven may not unlock for a few hours at the most.
3/31/2011 5:07:53 AM •
GE...
Answered
on Mar 31, 2011
Ovens won't heat
Have you set the clock alot of ovens need the clock set so the oven will work, this is a safety thing so if you set the oven to turn off after 1 hour or at a certain time of day and say the power went out or the gas was turned off and came back on then the oven won't just start up on its own
3/9/2011 10:36:58 AM •
GE...
Answered
on Mar 09, 2011
Oven Light Will Not Shut Off - GE Range Oven Model: PS968SP1SS
If you have already replaced the Hi-Amp Door Switch on your GE Range Oven (Model: PS968SP1SS), but the oven light still will not turn off, there are a few additional steps you can take to troubleshoot the issue:
- Check the light switch: Ensure that the light switch is functioning properly. It is usually located near the oven door frame or control panel. Press the switch manually to see if the light turns on and off. If it is not working, you may need to replace the light switch.
- Inspect the light socket: Examine the light socket for any signs of damage or corrosion. If the socket appears to be damaged, you may need to replace it.
- Verify the wiring connections: Check the wiring connections between the light socket, the Hi-Amp Door Switch, and the main control board. Ensure that all connections are secure and properly connected. Loose or faulty wiring can cause the light to stay on.
- Test the main control board: As you suspect, a faulty main control board could also be the cause of the issue. You can try resetting the control board by turning off the power to the oven at the circuit breaker for a few minutes and then turning it back on. If the light still does not turn off, it may indicate a problem with the control board that requires replacement.
If you have performed these troubleshooting steps and the light still won't turn off, it would be advisable to contact GE customer support or a qualified technician for further assistance. They will be able to diagnose the problem more accurately and recommend the appropriate solution.
6/18/2023 4:55:39 PM •
GE Ovens
Answered
on Jun 18, 2023
