20 Most Recent
Honeywell RTH8580WF WiFi Thermostat Questions & Answers
Wiring Honeywell 9580 to old furnace with no C wire
This is not going to be easy. Check the wiring in the wall to look for the third wire. If they did not run one, you have to run new wire to the furnace and thermostat. If they stapled that wire to the walls inside studs, then it is going to be even harder to run the new wire. Once you run that new wire then you have to locate the connection in the furnace that has the common (c) wire for the transformer. Check you tube to see if the have any how to video.
10/13/2015 2:34:36 AM •
Honeywell...
Answered
on Oct 13, 2015
I have rth8580WF and heat pump in my condo. When I
Press the FAN & the up arrow @ the same time to get into installation programming. Follow the set up numbers correlating to options in the install instructions...Make sure it is programmed for heat pump & if you have Auxillary heat. Hit Next until you get to the reversing valve position O or B ( reversing valve energized in a call for heat or cool) and switch it to the opposite of what is in the current program. Hit Done & you should be good. Hope that helps.
12/12/2013 11:24:57 PM •
Honeywell...
Answered
on Dec 12, 2013
I have installed RTH8580WF thermostat for heat
12/12/2013 11:23:42 PM •
Honeywell...
Answered
on Dec 12, 2013
No wifi connection
The WiFi has to be on. to get to the main programming, press fan & the up arrow @ the same time for about 5 seconds. Now that you are in the programming mode, you need to scroll through to, I believe level 39 and turn it ON. This will enable the WiFi. Then press done to get out of programming mode. Your thermostat should start searching now as long as there is WiFi to connect to. Then you need to register the stat. Hope that helps.
12/10/2013 12:05:26 PM •
Honeywell...
Answered
on Dec 10, 2013
Isnt showing wifi set up
12/10/2013 12:03:50 PM •
Honeywell...
Answered
on Dec 10, 2013
