GE Ovens • Uploaded on Sep 25, 2013
An F9 error code on a General Electric (GE) oven indicates that the oven's electronic control system has detected a problem with the automatic door lock. The automatic door lock mechanism prevents the oven door from being opened when the oven is set for "Clean" mode. The malfunction may be a jammed door lock mechanism, a pinched or broken wire, a faulty lock switch or a fault in the control board itself. general electric stoves with electronic controls, if there is a problem it will display the problem with a F followed by a number here are some of the codes and what they mean. F1----STUCK KEY--DAMAGE CONTROL F2----OVEN TEMPERATURE EXCEEDS 590 DEGREES WITH DOOR UNLOCK F3----OVEN SENSOR DEFECTED F4----OVEN SENSOR SHORTED F5----ELECTRONIC CONTROL NEED TO BE REPLACED F6----THERE IS A PROBLEM IN THE KEY PANEL F7----REPLACE KEY PANEL F8----COMPONENT FAILURE F9----DOOR CIRCUIT---LOCK MECHANISM OR WIRING FC----DOOR LOCK CIRCUIT FAILURE FD----PROBE OR RECEPTACLE FAILURE FF----ELECTRONIC CONTROL FAILURE HOWEVER ON THE MORE EXPENSIVE MODELS AND PARTICULAR THE DOUBLE WALL OVENS THE COMPUTER CONTROL AND THE TOUCH PAD ARE TWO SEPERATE COMPONENTS. THE TOUCH PAD IS USUALLY IN THE GLASS FRONT THAT COVERS THE CONTROL--ON THESE MODELS YOU WILL SOMETIMES GET A ---F7--CODE---- WHENEVER THERE IS A-- F7--OR--F1--ON THIS MODEL IT MEANS THE PROBLEM IS EITHER IN THE CONTROL OR IN THE TOUCH PAD
Disconnect power to the oven.
23 questions posted
293 Questions
216 Questions
128 Questions
114 Questions
86 Questions
