20 Most Recent Lasko 5610 Baseboard Heater Questions & Answers
Schematic plf504d thermalinc
My experience with Lasko heaters is with the small portable ceramic types. On mine there are two knobs. One is the "Power"; the fan symbol is for fan only, then (I) Low Power and (II) High Power 1500 watts. The other know is the thermostat from (-) to (+). Set the thermostat towards (+) until the temp in the room is the way you want it. Then turn the thermostat know towards (-) until the unit shuts off. This is now the temperature setting and the heater will cycle on and off to this setting. Hope this helps.
1/13/2014 11:50:37 AM • Lasko 5610... • Answered on Jan 13, 2014
Baseboard heater was plugged in and shut off on
check your breakers
1/29/2010 6:42:38 AM • Lasko 5610... • Answered on Jan 29, 2010
Our Lasko 5620 has a digital control, but we can't
Based from your comments, it seems that you have a
defective digital control. Have a check up for this item.
It may need to be replaced. Hope this will help you.
1/10/2010 6:53:12 AM • Lasko 5610... • Answered on Jan 10, 2010
Cannot get the heating element to turn off properly on Lasko 5620
From whatI have seen on base board heaters if I recall correctly, the thermostat may be sepperate. Usually thermostats on these have a round knob. 1 line goes to this and the other side of the thermostat goes to 1 end of th element and the othe line attaches to the other side of the element. Its possible you have the element wired in directky if it came without a thermostat and without instructions it may till be connected directly. You should have an L1 and L2 connection and hope there is a wire diagram on the cover.
THE reason these basebord heaters used to come without a thermostat is because they are (OR WERE)set up to add on additional heaters comming right on down the wall. At the last one you could tie in and get a correct rated thermostat installed in the center of the series.
Return to LOWES and ask them to remove the instructions and copy them for you from another like model. Or have them contact the manufacturer and request they fax a copy of instructions with a diagram. Also ask if the heater comes with a thermostat. It may stoill be sepperate in another kit.
3/5/2009 3:39:00 AM • Lasko 5610... • Answered on Mar 05, 2009
3answers
Lasko 5610 red caution light, no power
the thermal resister between the two reset breakers on the bottom is what the problem with mine was
4/15/2008 1:13:05 AM • Lasko 5610... • Answered on Apr 15, 2008
Where can I find a wiring diagram for a lasko heater model # 5624
https://search.yahoo.com/search?fr=mcafee&type=E210US1494G0&p=wiring+diagram+for+a+lasko+heater+model+%23+5624
12/13/2023 11:24:07 PM • Lasko Heating &... • Answered on Dec 13, 2023
Lasko CT14320 heater. I dropped it, and it turns on but won't run. I smell burning.
Normally they have a tip over switch in the base. If the tip over is activated there should be nothing, no heat, no fan. It sounds like yours is heating up and burning dust in side it, but the fan isn't running. If you can open it up, you can see if the fan has been dislodged. A new one is $40 at Walmart. https://www.google.com/search?q=Lasko+heater+CT14320 ..
12/7/2023 4:28:13 AM • Lasko Heating &... • Answered on Dec 07, 2023
How to change filter on my Lasko model 5560 Tower Fan Heater?
Question edited for clarity. They show your model, and if it has a filter (not mentioned in specs), My guess is the you lift up the black piece at the rear. https://lasko.com/collections/lasko-heaters/products/lasko-5560-digital-tower-heater-with-remote The manuals are very basic and your model isn't listed. Model 5309 below. http://images.salsify.com/image/upload/s--U1j83tBG--/fsxod4mxrt0iju3nfsdv.pdf There is a contact link if you click Support on the upper bar. https://lasko.com/pages/product-instruction-manuals .. Videos that MAY help?
9/9/2023 12:01:16 AM • Lasko Heating &... • Answered on Sep 09, 2023
What tools do I need to take apart a Lasko 5812 heater?
Question edited for clarity. Question moved from Television and Video. Probably a screwdriver, pliers and sidecutters. https://www.google.com/search?q=Lasko+5812+heater+replace+cord ..
2/15/2022 9:49:52 PM • Lasko Heating &... • Answered on Feb 15, 2022
2answers
I have a Tower Lasko heater and the red light came on and no heat??
My heater just has on the red light no heat what to do anybody know
2/19/2021 1:02:27 PM • Lasko Heating &... • Answered on Feb 19, 2021
How to replace power cord on lasko oil filled heater
what model?
1/6/2020 2:58:48 AM • Lasko Heating &... • Answered on Jan 06, 2020
I am currently using a Lasko 5812 heater. The problem is it keeps shutting off, especially in the high setting. How do I fix this?
SAFETY FEATURES 1. A Tip-Over Switch is built in to prevent operation if the Heater is tipped over.2. A thermal overload protector is built in to prevent overheating.3. If an overheat temperature is reached, the Heater will automatically shut off. It can only resume operation when the user resetsthe unit.To Reset Heater:1. Unplug the Heater and wait 10 minutes for the Heater to cool down.2. After the Heater has cooled down, plug the unit into a 120V~ electrical outlet and follow the operation instructions describedin this manual. TROUBLE SHOOTING TIPS If your heater shuts off unexpectedly or fails to operate, one of the above-mentioned safety features may have been activatedto prevent overheating.1. Be sure the power cord is plugged into a working electrical outlet.2. Check your heater for obstructions blocking air flow and remove them.3. Make certain the Heater IS NOT FACING a wall or large object; this may restrict the air flow.If you have a problem that can not be resolved by the steps listed above, contact Technical Assistance at 800-233-0268, Monday throughFriday, between the hours of 8am and 5pm
2/20/2019 11:05:02 AM • Lasko Heating &... • Answered on Feb 20, 2019
My Lasko Movable air heater just quit working . Model 755320 4156 FA06114014696 Intertek 3075290
I have 2 screws on this same model 6221 that will not release.. At least I am assuming they are screws one in the top corner and one in the bottom corner.
1/28/2019 4:15:36 PM • Lasko Heating &... • Answered on Jan 28, 2019
2answers
How to replace the over heat switch on a lasko 5622 heater and how to tell if this why heater shuts down after 5 minutes . I have cleaned heater and it still shuts down
Bench test. With heater tore apart, energized, a volt meter connected across the sensor will indicate a voltage when it opens. take note of aproximate temperature and compare with the sensor temp rated value. It takes a bit of skill to trouble shoot, repair, and put it back together. Toss it out if in doubt.
1/24/2019 2:41:54 PM • Lasko Heating &... • Answered on Jan 24, 2019
I have a lasko 5622 heater that cuts off after 5 minutes, what is wrong and how to repair
Either the Overheat switch, or perhaps the Tilt switch is shutting down the unit. Make certain there is nothing in front of the unit. Make certain the unit is flat on the floor.
1/22/2019 12:14:17 AM • Lasko Heating &... • Answered on Jan 22, 2019
Lasko 5610 Baseboard Heater Logo
10 questions posted
Top Lasko Heating & Cooling Experts
Arnie Burke
Arnie Burke
ADMIN Andrew
ADMIN Andrew
Kardoc
Are you a Lasko Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Lasko Heating & Cooling
Most Popular Question
lasko 5610 red caution light no power
  • Heating & Cooling
