20 Most Recent
GE 168952 Deep Fryer Questions & Answers
It does not power on.
The cord is bad. We found that by jiggling the cord, the unit started to heat again. We are currently looking for a replacement cord for ours also.
Fryer problem
The problem is with your cordset if it is a DP16, Here's how to fix it.
Solution for fixing DP16 Cordset for GE deep fryers:
To begin with, you willl need to clean the electrical contacts on both the fryer and the cordset. They will be burnt from electricity arcing between the two when the cord is plugged into an outlet before connecting to the deep fryer.
I used a dremel tool attachement grinder used for sharpening chain saw chains. It is cylindrical and fits in the holes in the cordset perfectly. You could use sandpaper rolled into a small cylinder, or whatever is available that will do the job. To open the flaps that cover the holes, insert a toothpick in the center hole of the cordset while you work. Make sure that both sets of contacts are completely clean before proceeding with the next step.
Next, using needle nose plyers, make two tight coils of fine or extra fine (.032") resin core solder the same size as the holes in the cordeset. Press into place in each of the holes in the cordset against the electrical contacts. Spread the coils a little so they cannot fall out when the cordset is not attached to the fryer because the flaps will likely not close properly or at all. You can work the coils down so the flaps will close if you use the .032 solder, but they will still be a little loose, so they might jam the flaps open or partially open.
This definitly isn't a UL approved method, but it will fix the problem completely. Happy frying!
When i went to go use my deep fryer the other day
If it uses the DP16 cordset, that is probably your problem. If not, find and press the reset button.
My ge deep fryer will not turn on
If your fryer uses the DP16 cordset, this is probably your problem. If not, find and press the reset button.
No power lights will not come on no power
If your fryer has the DP16 cordset, this might solve your problem. Otherwise, have you press the reset button. It's hard to find, but it is there.
Need replacement cord set (DP16)
If you have your old cord, the following will probably solve your problem.
Ge dp16 cordset
Ge customer service at 1-800-267-0516 needs to hear from enough requests and GE will refill DP16 (item#227366)power cords in stock at GE for Fryer model #168952. "There made to order with enough requests or complaints"-Cust. Serv.
So with this info, everyone please call with item number above model 168952 and state you need a new DP16.
Hope this is helpful!
Chuck-NJ
Looking for a dp 16 cordset
You can find replacement cords for many counter top
appliances at most appliance and building supply stores. Try Ace, Home Depot, Lowes. Take the cooker with you to make sure you are getting the correct cord.
Most of these fryers have trip on the rear of the element unit. Search for the trip and reset, if this does not sort out your problem check the fuse in the plug if you are in Europe.
Regards
Alan Hood
ami-man
