20 Most Recent
GE Advantium SCA2001BSS Microwave Oven Questions & Answers
Change spark
Check diode and capacitor. Instructions should be found inside the unit.
Repair
please see this details and fix it. God bless you1. No power to outlet (overload or fault in microwave or other appliance).
2. Blown main fuse - likely due to other problems.
3. Open thermal protector or thermal fuse.
4. Defective controller or its power supply.
5. Clock needs to be set before other functions will operate (some models)
I have a GE Advantium
They are the same the SCA2001Bss is a newer production model.
Order the Magnetron from Bi Coastal Appliance Parts @ 1-800-673-1262
Part # WB27X10327
Advantium -- wont cook
The solution to this problem is to replace the magnetron. I had the same symptoms, and I got a used magnetron and replaced it. It takes some advanced electrical skill, and you have to disassemble the oven all the way to the inside stainless steel. I have the same exact model, manufactured in November of 1999.
Microwave lights and fans
If the microwave sounds normal, but not heating, then the magnetron is bad and needs to be replaced. If it is making a humming noise, then the diode is bad. I recommend that if it is the magnetron, ou also replace the diode.
After replacing the door latch,
The capacitor is bad and will need to be replaced,
Please make sure that you know what to do and how before attempting repairs on a microwave...they can be deadly...
Here isa tip that will help you to figure out what is wrong with your MicrowaveOven....
Microwave Oven Basic Troubleshooting Tips
heatman101
My wireless USB transceiver for
No the logitech mouse will not work with the microsoft receiver. The reason why is that they are on 2 different frequencies. If they were on the same frequency then you would be ok but they are not.
