20 Most Recent
ICOM Informatique Icom Radio IC-F3, IC-F4, IC-T2A Compatible Battery Questions & Answers
Can I us a cp100 with an icom
Yes. Both must be programmed to the same frequency and DPL code ( if digital) or TPL code ( if analog).
7/11/2014 11:41:23 PM •
ICOM...
Answered
on Jul 11, 2014
1 have a icomf3s-3 32 channeli can ony see 16
Hi, the problem is you only have 16 channels programmed in the radio. you can program the full 32 if you have- the software, http://hamradio.online.ru/ftp/dw.php?icf3f4.zip . And the programming lead- http://cgi.ebay.co.uk/USB-Interface-cable-for-ICOM-IC-v8-Radios-6-030_W0QQitemZ330356207021QQcmdZViewItemQQptZUK_ConsumerElectronics_SpecialistRadioEquipment_SM?hash=item4ceac3adad&_trksid=p3286.c0.m14
Hope this helps.
9/10/2009 6:01:38 PM •
ICOM...
Answered
on Sep 10, 2009
Icom bc-179 do not charge the battery
Charging a battery requires two components. A working charger and a functioning battery. The concept is simple. A battery charger must output more voltage than the battery does, and at an acceptable current level. First determine the battery output from the ID sticker, then measure the charger output. It must be 1 or 2 volts more than the battery output. If the charger is working, charge the battery overnight. If the battery does not charge or runs down quickly, the battery must be replaced. All batteries have a limited number of charge cycles. The most common problem with Ni-Cad batteries happens when they are re-charged before they are completely discharged. Recharging a half used Ni-Cad sets up a short term memory and the battery discharges faster than normal.
12/30/2016 5:56:30 AM •
ICOM...
Answered
on Dec 30, 2016
Can't get icom a6 radio unlocked
Copied this from their manual:
The lock function prevents accidental frequency changes and accidental function activation. q Push (looks like f) , then push [7• ] to turn the lock function ON. •" " appears. (looks like f) To turn the function OFF, repeat step 2 above. •" " disappears.
http://www.icomamerica.com/en/products/avionics/handheld/a6/default.aspx
9/21/2016 6:48:10 AM •
ICOM...
Answered
on Sep 21, 2016
