20 Most Recent
Kenwood ProTalk UBZ-AM14 (14 Channels) 2-Way Radio Questions & Answers
Hello,I have four walkie talkie
Elio:
Your local Kenwood rep is correct for a couple of reasons:
1. The cost to modify your current radios to operate on the Italian band would be higher than the price of new radios.
2. Operating modified radios would be a violation of Italian laws.
Bill B
Kenwood TS-430s FM 430 board keys up but no modulation
First, clean all the connectors associated with this board. Over time they can get corrosion built up on them and they stop conducting. Use De-OXIT or Isopropyl alcohol to clean them. You may have to clean the deviation control on the board or replace C* and C10. I doubt if the microphone amplifier, Q1, is bad but if you can check the voltages around it, that might give you a clue. This problem shouldn't be too hard to fix as the rest of the radio is working. Good Luck!
I want Kenwood TK 8160 programming software
Do you indeed!
No problem, it is $76.00.
Kenwood TK-8160K ' Software - American Communication ...
https://www.ameradio.com > Kenwood > Software
Reliable Accessories for KENWOOD TK-8160 UHF Conventional Mobile Radio, 450-490 MHz, 25W, 128 Channels, ... Windows® Programming Software for KDS-100.
Kenwood TK-7160HK ' Software - American Communication ...
Windows® Programming Software for KDS-100. Compatible with KENWOOD TK-7180, TK-8180, TK-7160, TK-8160, TK-7150, TK-8150, TK-980, TK-981, TK-7102H, TK-8102H, ...
Programming a TK-5320 using KPG-112DN V.2.20 keep getting "LOC" in display before the name of the channel.
Yes, radio. Check your cable. Is it OEM? Try plugging it into the radio before launching the software. Then try after launching the software. Is it a USB or Serial cable? If serial, the USB adapters often do not work. I have one brand of radio where I need to restart the computer each time I program so it will read the Serial to USB correctly. Even then, I may need to go into device manager and enable/disable it 2-5 times. I do not know if the software is the latest, but if a radio is programmed with the newest software, you cannot go back to an older version 90% of the time.
I kenwood TK-2000 radios. when I read the radio, all the frequencies listed are vhf frequencies.but when I program a vhf frequency it says it is out of band it can only accept 400 to 440 mhz.
Based on the information you provided, it seems like the Kenwood TK-2000 radios you have may have been programmed with the wrong band split. The TK-2000 is available in both VHF and UHF frequency ranges, and it's possible that the radios you have are actually UHF models, despite being listed as VHF frequencies when you read the radios.
To check if your radios are UHF or VHF, look for a label on the back of the radio that specifies the frequency range. If it says UHF, then the radios can only accept frequencies in the 400-440 MHz range. If it says VHF, then the radios should be able to accept frequencies in the VHF frequency range.
If you've confirmed that the radios are indeed VHF models, then it's possible that the band split settings may need to be adjusted in the programming software to match the specific VHF frequencies you're trying to program. I recommend checking the manual for your programming software to ensure that you have selected the correct band split settings before programming the radios. If you're still having issues, it may be helpful to contact Kenwood customer support for further assistance.
