20 Most Recent
Goldstar DH504ELY6 Dehumidifier w/ 50 Pints Per Hour Capacity Questions & Answers
The dehumidifier runs and collects water. The
My only guess is that there must be a relay inside the control panel that (like many relays) arced ar one time and partially welded itself in the on position. Good quality relays are plated with a high temperature melting point metal to prevent this. Being LG is Goldstar (a Korean company) they most likely use the cheapest relays. To solve this issue the relay needs a hard knock to it. (Don't hit it so hard as to break the circuit-board) :)
11/11/2023 12:13:52 AM •
Goldstar...
Answered
on Nov 11, 2023
Stopped working
Does it act the same as if the bucket was removed? Likely your fill bucket switch is not connecting. Remove the bucket, press the switch and try to run the unit. If it powers up and "works" then you need to make sure the bucket has a good connection with the switch. If this did not work, remove the connectors to the switch and electrical tape them together and try running this again. If it works, your switch is bad. Replace. If you leave it electrical tape connected, the unit will not turn off when the bucket is full.
1/13/2014 5:33:53 PM •
Goldstar...
Answered
on Jan 13, 2014
Is a gold star dehumidifier supose to be noise
I can't hear YOUR dehumidifier and can't tell if it's out of the ordinary, but dehumidifiers have all the same internal parts as a refrigerator with the addition of a fan to blow air through the coils to keep them from freezing up. They do tend to be a bit noisy.
2/22/2015 7:52:30 AM •
Goldstar...
Answered
on Feb 22, 2015
Charge the compressor
unplug and wait a few minutes then reconnect to power to clear buttons not working , then ck filter to see that its not clogged use a flashlight to view inside to see if a heavy coating of dust exists iniside case , if so you might be able to save it if you unplug and remove case to access inside and clean out with vacuume hose coils are most important to get clean
10/23/2014 1:55:43 AM •
Goldstar...
Answered
on Oct 23, 2014
