20 Most Recent
Windchaser 3-way Oscillating Fan Questions & Answers
Cooling fan not turning
You need to replace it.
Which cooling fan? There are sometimes several and the hardest one to replace is in the power supply. If you are handy with tools and don't mind the work, you can replace it yourself, otherwise you will have to get someone to do it for you.
Blade broke
Look up zorotools.com and they should have a fan blade you can use it is most anything you can think of so maybe you can find the fan blade you need. Hope this will help Norm.
Humming noise from motor of oscillating fan.
Wd-40 is not a very good lubricant. It only lasts fror a few days and then dries up again. In order to get your fan working again, take some 3-in one oil and put a drop at the bearing side of each bearing top and bottom with the shaft upright. Spuin and tap the motor briskly with a small tack hammer or screw driver handle. This will impact and allow the oil to get into the bearings Keep tapping and turning until you feel it lighten up a spin freely. Turn it over and do the same thing again. I garuntee that all will be fine after this.
