20 Most Recent
Microsoft Windows® Vista® Home Premium Full Version OEM for PC Questions & Answers
Need a activation key
their is no others way how get the serial key of your win vista if you don't have a original authenticate label on CPU/unit,CD manual or u lost the original key...the best way is buy a new or ask your supplier and get a original copy serial key...
good luck and best regard
6/18/2009 9:07:36 AM •
Microsoft...
Answered
on Jun 18, 2009
Product id 89572-OEM-7332166-00019 what is vista home basic activation key ?
try calling the registration centre, they are very helpful and may well solve your problem but you ned the correct number for your OS/
To start the Product Activation Wizard, follow these steps:
- Click Start
Collapse this imageExpand this image
- Right-click Computer.
- Select Properties.
- At the bottom of the window, click Activate Windows.
In the Product Activation Wizard, follow these steps:
- Click Use the automated phone system to activate.
- Click the drop-down menu, select the location that is nearest to you, and then click Next.
- The Product Activation Center telephone number is displayed at the top of the window.
Checksum
This may help. If you can't identify the file or program, then use MSConfg. Go to Start > Search. Type MSConfig. Go to the startup tab and disable as many items as possible. Not to worry, the apps are still there and critical items will load anyways. Plus this will make you pc load and run faster.
Youtube
On Internet Explorer click on tools choose popup blocker make sure the top line says turn on popup blocker then click on popup blocker settings and tighten up the security.
Terry
I need the product key of windows vista starter?
Supplying product keys for Microsoft products without paying for them is theft and piracy, both of which can create issues for the fixya website and the good things we do here. Please do not ask for keys here. Also members who supply such keys are violating the terms of use issued by fixya, and can have their accounts terminated. Yes they can come back with a different user id and email address, but they are jerks, and don't care about honesty and integrity. most computers have keys on them, usually have a COA sticker somewhere on the case. MS Windows (ALL versions) and Office (Word, Outlook, Powerpoint, Publisher) are NOT free, and keys should be purchased.
Uninstall ask
to remove ask toolbar .double click my computer.you will now see your c drive, at the top of the page you will see uninstall or change programs,click this then you will see a list of programs ,find ask toolbar in list click on it and click on uninstall and follow directions.
dt
How do i reset my email fonts
Changing font size for reading in Outlook and Gmail
To read Mail in a larger font in Outlook:
- Hold down Ctrl while turning the scroll wheel on your mouse down.
In Outlook 2007 and later, alternatively
- Open the message in its own window.
- Click Other Actions.
- Select Zoom... from the menu.
- Choose the desired zoom level.
- Click OK.
Outlook will not remember the zoom level.
Since this does not work with plain text emails (the mouse wheel does), also select Tools ' Options... from the menu, go to the Mail Format tab, click Fonts... and use the Choose Font... button under When composing and reading plain text: to choose a bigger font. The above instructions are courtesy of About.com.
Here is a link referring to reading Gmail.
https://readingonscreen.wordpress.com/text-adjustments/gmail-text-size/
Comcast router not working with vista
more info needed cindy. Comcast router connect -
is that via ethernet you know the cat5 blue cable stuff ?
or is it via some other networking equipment like for example
WI FI router or access pont or via a hub or via a switch ?
what is the internal ip address of your router ?
does the router assign ip addresses via DHCP .?
Have you set the Vista P.C to obtain IP address automatically in the network settings ?
How is it not connecting ?
