20 Most Recent Motorola T5522 (7 Channels) 2-Way Radio Questions & Answers
Devices not linking
http://shop.giantintl.com/Manuals.asp?offset=30
12/17/2015 12:23:43 PM • Motorola T5522... • Answered on Dec 17, 2015
Ive got a set of Motorola t5522 walkie talkies,but
You will find the manual here: www DOT giantintl DOT com/ContentManage-new/manuals/Moto/T55xx DOT pdf Best regards
9/3/2013 2:10:39 PM • Motorola T5522... • Answered on Sep 03, 2013
Needs user manual
Here is a link to the T5500 series user guide: http://www.giantintl.com/ContentManage/manuals/Moto/T55xx.pdf
Best regards.
11/1/2010 11:05:50 AM • Motorola T5522... • Answered on Nov 01, 2010
I have 2 T5428 radio.How
Here is a link to the manual http://www.giantintl.com/ContentManage/manuals/Moto/T5320_T5410_T5420_User_Manual_E.pdf
You will find programming instructions starting on page 15.
Program the frequency and interference eliminator code to match one another. For simple operation set the code to off (zero).
Best regards.
8/13/2010 3:56:43 AM • Motorola T5522... • Answered on Aug 13, 2010
Need a manual for my t5522 2 way radio
10/8/2009 12:00:14 AM • Motorola T5522... • Answered on Oct 08, 2009
I need user mannual of Motorola T5428
7/3/2009 3:23:19 PM • Motorola T5522... • Answered on Jul 03, 2009
I need a user manual for the Motorola T5522 two
Here is a link: http://www.giantintl.com/ContentManage/manuals/Moto/T55xx.pdf Have a nice weekend.
6/6/2009 4:11:22 AM • Motorola T5522... • Answered on Jun 06, 2009
Motorola T5522 Talkabout
A User's Manual for Motorola CLS series is available online here.
It's file name is Motorola CLS Manual (PDF).
You would need Adobe® Reader® to view PDFs.
3/31/2009 6:24:50 AM • Motorola T5522... • Answered on Mar 31, 2009
I NEED MOTOROLA T5522 USERS MAUAL
Here is a manual link which says it covers the 5500 through the 5550. http://www.usersmanualguide.com/motorola/2-way_radio/t5500
3/23/2009 4:36:26 PM • Motorola T5522... • Answered on Mar 23, 2009
What is "vox"? why is
In radio communications, "voice activation" or "VOX" has been used for decades where convenience or the need for hands-free operation rule out push to talk. The idea is simple: monitor the microphone input and transmit only when the user is actually talking.
12/26/2008 7:02:37 AM • Motorola T5522... • Answered on Dec 26, 2008
MOTOROLA T5522 BATERIES
Hello mironas3,
A general rule of thumb when dealing with rechargeable battery packs is to take the capacity of the battery divided by the charge rating of the charger and then add an additional 10%.
Offhand I am not sure what the voltage / capacity or voltage / charge rating of the battery and charger are but you can determine that by examine the labels on both items. Let’s say (for example) that your battery is listed as 7.2 volts and 1,000 mAH and your charger is rated as 9 volts and 100 mA. (These are just theoretical examples. Substitute the numbers from your own items.) You would divide 1,000 mAH by 100 mA to equal 10 hours. Then add 10%. So you expect a full charge to take around 11 hours time.
Of course, actual charge time will vary depending on how discharged the batteries are when you start charging them. Since the charger that Motorola provided doesn't have a charge indicator determining when the batteries are done charging is a matter of making an educated guess. If you touch the batteries while they are charging and they feel warm to the touch, that's a pretty good indication that they are done or nearly done charging as once the batteries are topped off excess power will turn into heat. (Note that batteries in a charger should never be HOT. If they are ever more then just slightly warm, something is wrong with the battery or the charger or both.)
Also, just a word of warning here: remember to always use the correct manufacturer recommended charger. Substituting a charger with twice the charge rate to charge the batteries in half the time is not a good idea. Rechargeable batteries are meant to be charged slowly. Fast chargers exist but they typically have built-in circuitry that pulses the charge rate to prevent the batteries from overheating. Using the wrong charger can result in damage to your battery or radio or worse could possibly even lead to a fire.
Best Regards,
Ken
"Go Ahead. Use Us."
7/28/2008 5:35:11 PM • Motorola T5522... • Answered on Jul 28, 2008
No idea of operating
here is the link for the manual; http://www.motorola.com/mdirect/manuals/T50-T55_UserGuide.pdf Sorry for delay Hope this helps :)
7/20/2008 10:58:42 AM • Motorola T5522... • Answered on Jul 20, 2008
2answers
T5522
Yes I have fixed the problem thanks. If you like to know how you can join my premium plan costing just £12.99 a quarter.............
Touche
4/23/2008 9:32:09 PM • Motorola T5522... • Answered on Apr 23, 2008
Programming Motorola XPR 3500e please?
https://www.google.com/search?q=motorola+xpr+3500e+programming
MOTOTRBO XPR 3000e Series
Motorola Solutions https://www.motorolasolutions.com > portable-radios > x... Integrated Wi-Fi; Over-the-air software updates; Bluetooth® audio; Enhanced audio quality; Channel lock (XPR 3500e only); Improved expandability ...
MOTOROLA XPR 3500e UHF PORTABLE RADIO
Wi-Com Solutions Inc. https://wicom.ca > product > motorola-xpr-3500e-uhf-p... MOTOROLA XPR 3500e UHF PORTABLE RADIO. $1,298.00. With this dynamic evolution of MOTOTRBOâ„¢ digital two-way radios, you're better connected, safer and more . ..Not sure is this is relevant
3/23/2024 5:46:16 AM • Motorola Radio... • Answered on Mar 23, 2024
I have a pair of Motorola MS350 radios. 1 works fine but one does not receive or transmit. I have both radios set up the same.
If your frequency and code are set the same, you have either a battery problem or a radio problem. For a quick battery test, swap the battery pack from the good radio into the one with the problem and see if the problem moves. Then you will know if it is simply the battery. If both settings are identical and the battery swap does not solve the problem, you have a defective radio.
2/12/2024 3:14:21 PM • Motorola Radio... • Answered on Feb 12, 2024
Motorola T5522 (7 Channels) 2-Way Radio Logo
19 questions posted
Top Motorola Radio Communications Experts
eradiostore
eradiostore
ZJ Limited
ZJ Limited
ExpressFiX
ExpressFiX
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
  • Motorola Radio Communications
Most Popular Question
need manual t5522 2 way radio
  • Radio Communications
