20 Most Recent
Apevia Laptop Keyboard for Acer Aspire 4520 4710 Questions & Answers
Hiiiii
try cleaninf out the dvd lens...\
ur dvd lens might be dirty..
it is the main cause in many users and solved by cleaning the lens..
i can get a cd/dvd lens cleaner in computer store.....
use cd cleaner
Need to replace aspire 4330 keyboard.
Not that I'm endorsing this person...but heres 1 example. The price is reasonable as well.
http://cgi.ebay.com/New-Acer-Aspire-4730-4930-4330-Keyboard-&-Skin_W0QQitemZ170350771635QQcmdZViewItemQQimsxZ20090629?IMSfp=TL090629201003r30405
I need to replace keyboard from acer 4330. any
Hi there.
Remove the laptop battery and the AC power supply, open the lid as far back as you can take it.
Get
a small flat headed screwdriver, now, you have to take off the keyboard
bezel, this is the strip of plastic above the keyboard with the power
button on it, the best way to remove it is to start by the on/off
button by gently prying the bezel up from the lid hinge, once you have
one side out gently pull it up using your fingers, it will unclip and
lift away.
Next you have to remove 2 screws from the top of the
keyboard, these should be visible to you, once the screws are out
carefully lift the keyboard up, you will see a ribbon cable that is
connected to the motherboard, gently pull the tab up on the connector
that the ribbon cable sits in and it should release it and you can now
remove the keyboard and replace it.
To re-assemble just follow my direction in reverse.
Please post back with the results and for any additional advice if needed.
Good luck and thanks for using FixYa!!
Cand format by xp
Keep in mind buddy!! when you install any operating systems there's always a chance some drivers will not load. You might have to update windows service pack or manual install drivers for your pc.
good luck!!
Take off keyboard
You probably don't want or need to do that.
Just get some canned air, and spray away whatever debris is in the keyboard.
Taking it apart is a pretty bad idea.
Aspire 4736z422g25mn
unplugged the cable, and pull out the battery for a few minutes, like a 15 min and conect all and try, its the problem persist change the internal watch battery
Aspire one d2500dr
I assume you're running Windows 7 or 8. In general, you can't uninstall wifi--but you can certainly turn off your antenna (usually a switch on the side or front of the laptop) or you can tell windows to forget about a particular network.From the sounds of it, you probably did one of the two and now you cannot connect to the Internet. If you want explicit instructions, I need to know which version of Windows you're running (XP, Vista, Windows 7, or Windows 8).
