20 Most Recent
HP L1908W 19" LCD Monitor Questions & Answers
Screen going blanck
Click Start Windows icon on your bottom left corner of computer
Type cmd in search box
You should see it as Program 1
Click and it will open a black command page
type this and then click enter
CHKDSK /R
It will then ask if you would like to schedule check next
time Windows re-starts so type Y
Restart computer for the check disk to begin
Pls note it make take several hours
Just let the computer do this task, when completed
Re-start your computer. Hope it solves your issue :)
I have a Hp L1908w
This seems to be problem of the electronics on the power / Inverter board.
If you can do electronic repairs I can guide you .
Samir
HP L1908W
When i turn on
First use an external light sorce like a LED flash light. With it close to the screen do you see a light ghosty image of the desktop?
If you do then either your backlight's or backlight power circuit have failed. If the monitor is not under waranty some repair shops may be able to fix the problem.
If there is no image then the LCD is not conecting to the main board and the monitor will need to be replaced.
If you want futher details on the first instance contact me
I have a HP L1908W
Oaky if you have taen the monitor aprat to point of actually seeing the back lights then you want to make sure there are no cracks near the ends and no charing mars on the reflective metal casings. if they are fine then the problem will be in the control circuit. This will be the board with the external power conection. There will be a series of Capacitors on this board. Look for ones that are slightly bulged on the back side. If you dont see any then look for grouping of them in 480-1000 f and ussualy between 10 - 25 v. These are what affect the watt load for the backlights. You can find replacements at most Radio Shack or electronic hobby shops. Use .032 diameter 60/40 rosin-core solder and no more then a 30 watt iron or you will scorch the board. Hope this helps, contact me if you need anything more specific.
My monitor goes black ever
If your monitor is going black every minute... It is most likely a problem with the backlight lamp or the inverter board that drives the lamp. Fixing this issue would require disassembly of the monitor and testing the lamp and the inverter board. Most commonly it is the lamp that burns out. The cost of repairing this issue with parts and labor is typically more expensive than replacing the unit.
