20 Most Recent Acer X243W 24" TFT wide format screen 24 inch LCD Monitor Questions & Answers
I have a wide screen Acer monitor, yet am unable
Sounds like either your display resolution needs to be set higher or when you bring up firefox after the page loads press and hold the ALT key and Click View, ToolBars and select Menu Bar. This will keep it at the top everytime you open firefox. Now under View you can zoom in and zoom out. You can also select Full Screen. *** Before doing anything did you click the middle box at the top right hand corner of the screen between the - and red x? This toggles between full screen also.
3/9/2018 11:31:18 PM • Acer X243W 24"... • Answered on Mar 09, 2018
2answers
Acer X243 monitor video flakes
Based on the troubleshooting you've done, this sounds like an internal heat management issue inside the monitor. One of the display elements is likely overheating (either due to age or a defect) which is causing the pixels in the display matrix to bleach out when the monitor warms up.
Your two best solutions for this one, unfortunately, are to either contact Acer directly to see if there is any kind of warranty, recall or known issue on the monitor; or replace it. Based on the age of the monitor, you're probably better off with a replacement anyway.
Hope this is helpful!
4/16/2014 4:35:41 PM • Acer X243W 24"... • Answered on Apr 16, 2014
0answers
I have tried all option on the Acer screen so the
The resolution is done at the PC video output setting, not at the monitor, you should set the PC video resolution to be at monitor native resolution: 1920 X 1200 @60Hz This will give the correct aspect ratio of your display.
3/26/2010 4:24:25 AM • Acer X243W 24"... • Answered on Mar 26, 2010
My monitor went dim and goes black after a few
I don't know what OS you have but there is a power management setting you might want to check. Most likely the monitor is set to go quickly into sleep mode at inactivity. Alternately I don't know what monitor you have but it might be a backlight Issue as well
1/7/2018 6:14:08 PM • Acer X Computers... • Answered on Jan 07, 2018
Forgotten password
I use a program called "locksmith" which is included on a "commander disk" that I have.
you can check at :
http://www.bootcd.us/ERD_Commander_2003.php I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
4/23/2024 9:24:47 PM • Acer Computers &... • Answered Yesterday
My new-bought Acer Aspire 3 has yellow acer logo when starting up, is it normal? Because in some yt videos, the acer logo is green
Perfectly normal. It depends on the internal timing of the GPU and the OS version.
4/17/2024 3:01:26 AM • Acer Computers &... • Answered on Apr 17, 2024
tip
Mpowering technology pop up
Couldn't get rid of mpowereing technology pop up. Tried every solution offered by the internet. Finally I noticed when I powered up my computer the pop up showed up even before the computer loaded anything. I turned off the power to the monitor and powered it back up an viola, pop up gone. The Acer monitor had generated the pop up.
2answers
My Acer X1110 switches off as soon as blue light comes on?
it needs service, and service manuals are hard to find on anything by the likes of ACER. this projector worked for 12 long years, did you own it 12 or bought a bad projector, no history told as I can buy dead projectors all day long. and hard nut problems even hacking done. Acer X1110 data projector Standard throw projector.. did you know most projectors have serious grade protective devices inside??? (tamper and overheating are 2) did you read owners manual page 32 yet, errors. LED codes.? there are 4 LED, and all 4 matter, projector turned (ON) (not one =1) also in pairs glowing and also if blinking or not, so read page 32 it tells all that. my guess is overheat failures, even cold, due fan slow or packed in lint after 12 years of use and no service done,. color-undefined-undefined-0.jpg https://manualzz.com/doc/49497108/acer-x1110-user-manual some have dust filtler a shop first cleans is out first, and check fan RPM with and LED tachometer. this is all SOP.
4/2/2024 4:37:58 PM • Acer Computers &... • Answered on Apr 02, 2024
''e'' button :acer empowering technology
That button can be set using the utility on your programs list
It maybe that you accidentally turned it off or set it to do some other task.
Start there first before re-installing the program that sets it.
That is on one of the cds that should have come with it and can be installed by itself.
1/25/2024 8:38:32 AM • Acer Computers &... • Answered on Jan 25, 2024
Gud day my motherboard model is acer b25h4-am pc i forgot the password in bios so i decided to clr_cmos jumper and take out the cmos battery to clear the password of my bios,
I would try starting up and go straight into the BIOS. Set up your system and reboot.
1/23/2024 7:25:53 AM • Acer Computers &... • Answered on Jan 23, 2024
2answers
I can't use bluetooth on my Acer Aspire 7520
This computer does not have Bluetooth capabilities and you can't make it, by adding a Bluetooth Driver. It would need a Bluetooth transmitter and receiver HARDWARE built into the computer at the time of manufacture.. https://icecat.biz/en/p/acer/lx.akg0x.146/aspire-notebooks-aspire+7520-6a2g16mi-1376542.html and this site actually says it. https://www.bhphotovideo.com/c/product/538918-REG/Acer_LX_AN20X_017_Aspire_7520_5757_Notebook_Computer.html/specs Wireless Wi-Fi: 802.11b/g Bluetooth: None ..
11/27/2023 12:05:13 PM • Acer Computers &... • Answered on Nov 27, 2023
Acer 7240 turns off when unplugged
bad battery
10/21/2023 9:29:10 PM • Acer Computers &... • Answered on Oct 21, 2023
CCFL Laptop Screen Inverter
If Laptop is ok and screen is ok then I suggest check the ribbon cable connectors. Are all wires ok ? For information, CCFL Service manual is here https://clubelectronicos.com/wp-content/uploads/2020/11/lg_inverter_t-con_board_repair.pdf and Acer Aspire 8930G Service manual is here Acer Aspire 8930G Service Manual (Page 107 of 119) ' ManualsLib
10/18/2023 1:07:27 PM • Acer Computers &... • Answered on Oct 18, 2023
Acer X243W 24" TFT wide format screen   24 inch LCD Monitor Logo
11 questions posted
Popular Products
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
View Most Popular
X Acer
  • X Acer
Most Popular Question
acer x243 monitor video flakes
  • Computers & Internet
