20 Most Recent Lanier P160 Handheld Cassette Voice Recorder Questions & Answers
I havent found one,but it appears simple enough to operate.Martel doesnt sell this unit anymore and i havent seen any I Manuals on the web.Looks like a quality unit though
Lanier P160... | Answered on Apr 28, 2010
The only people I know that can still fix old Lanier machines are clearvoice@cox.net.
They are trained on Lanier and worked there for many years.
Lanier P160... | Answered on Jan 26, 2010
All parts are discontinued, but clearvoice@cox.net still has a stock of Lanier parts.
Medquist fixes them for about $90 plus parts
Lanier P160... | Answered on Jun 25, 2009
Press the telephone button first with one finger and immediately after you press that button press the rewind button, The unit should go into rewind and erase should be flashing on the digital display. When the unit starts rewinding take your finger off of both buttons, if you keep them on ,then the unit will rewind and stop erasing .
Lanier Audio... | Answered on Dec 10, 2014
Some times the battery contact need to be pulled out a little bit. they are located down inside the battery compartment. You can stick a small screwdriver under the battery contact and bend it upward for better contact. If that doesn't work try removing the back cover and tightening the grounding screw, which is a silver screw located by the motor pulley hole. Sometimes this screw loosens up and then the ground is lost to the entire unit
It is under the flap located directly under the keyboard buttons. It is a slide switch and you can adjust it for a little recall or a lot of recall.
This unit most likely has a broken rewind/fast forward rubber belt. This is a very common problem and is easily fixed if you can acquire a new belt. Any place that services Lanier equipment should be able to easily fix this problem.
Look under the front of the unit and there is a tel ans switch this must be on to enable the unit to answer the call
Tape players need maintenance often. You have to replace the belt, clean the rubber roller with Rubber Renue, put grease on the odd spot and clean the head by rubbing clean white paper on it. Any electrical contacts like a volume switch etc need a contact spray to remove oxides etc. This should be done every 5 years or even more often if used more often.
Lanier Audio... | Answered on Nov 07, 2013
Lanier P160 Handheld Cassette Voice Recorder Logo
8 questions posted
Top Lanier Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Lanier Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Lanier Audio Players & Recorders
Most Popular Question
some buttons came off need
  • Audio Players & Recorders
