20 Most Recent Dell 968 All-In-One Printer Questions & Answers
2answers
My Dell 968 All-in-one printer
Did you try cleaning all of the rollers coming into contact with the paper? I use alcohol and/or rubber restorer.
7/18/2019 7:34:31 AM • Dell 968... • Answered on Jul 18, 2019
Dell 968 wont print/fax.
If the printer can copy a document under the glass, black and white and color, then it will be a driver issue. Make and model of your computer and operating system? 32-bit or 64-bit? Was the operating system recently installed/reinstalled/upgraded? What virus program and firewall are you using? https://www.instantprintersupport.com/dell-printer-support
8/31/2018 5:41:54 PM • Dell 968... • Answered on Aug 31, 2018
2answers
Dell 698 printer does not
Hi type in Google search Dell 698 printer driver download. .. cheers
2/14/2018 2:32:58 PM • Dell 968... • Answered on Feb 14, 2018
Scans from the Dell is quite large.
you can reduce picture size using any photo software best is photoshop, you may have microsoft picture viewer, and a lot of soft. Scaner may not let you less then 72dpi to get normal picture for print.
1/30/2018 6:13:29 PM • Dell 968... • Answered on Jan 30, 2018
Printer won't connect to wireless network
Please check you may have another wireless connection other than your own set as automatic, or more than one connection in your settings of the same name, so right click on your network icon in your task bar or in network connections in device manager and select view all wireless connections, click on it and when all the connections show, highlght, delete all of them, then close the window.
Your notebook should now indicate that it found new wireless connections, click on the popup and select your connection name and click connect, at this point you will be asked to enter the passkey if you have security enabled.
9/21/2016 7:43:54 PM • Dell 968... • Answered on Sep 21, 2016
How do I connect the printer to my laptop acer
mayra lopez, Most newer printers are connected to the computer using a USB port. Look at the printers installation instructions for proper install instructions. Thank You, Dell-Jesse L Dell Social Media and Communities
11/3/2014 1:28:09 PM • Dell 968... • Answered on Nov 03, 2014
Dell 968
Markw501, Th 968 has no windows 8 drivers/software and is not compatible with windows 8. Click this link and look for your model number to verify. http://dell.to/UMzvYJ V8
4/27/2014 1:30:31 AM • Dell 968... • Answered on Apr 27, 2014
WHAT SHOULD I DO ABOUT THE INK ERROR BECAUSE THE INK IS PLACED BUT STILL SAYS CONSULT USER GUIDE
Unfortunately, if the correct Dell cartridges are in place and fully seated, the cartridge missing message indicates that the sensor in the printer isn't correctly recognizing the cartridges. If you have used non-Dell cartridges or refilled cartridges, try new Dell cartridges and check for signs of ink leaking in the system. Some printers have a removable print head that can be cleaned or replaced. I'm not sure about this printer. If the printer is under warranty, contact Dell. I hope this helps. Cindy Wells
4/10/2013 10:11:26 PM • Dell 968... • Answered on Apr 10, 2013
Printer 968 for mac
I think there is no drivers for Mac. Just the printer does not support MAC OS
7/19/2012 6:59:44 AM • Dell 968... • Answered on Jul 19, 2012
Can,t find if fax was sent
Goto to the set-up in the software on the machine and select to have the fax print you a confirmation page, upon successful completion of fax being sent. That will fix your problem for the future, as for right now. There might be an option to print out all the history of your machines transmission that might tell you. But it wont give you a positive confirmation, will just show you the transaction. Good Luck!!
6/13/2012 11:36:50 PM • Dell 968... • Answered on Jun 13, 2012
Dell 968 All-In-One Printer Logo
112 questions posted
Top Dell Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Norman Weimar
Norman Weimar
Ngoro
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Dell Office Equipment & Supplies
Most Popular Question
bought installed brand new color inkjet
  • Office Equipment & Supplies
