20 Most Recent Lanier VW-160D Questions & Answers
I own the Lanier VW 110 Transcriber. When I
Hello really simple on the front small door is a switch that say SPK and MIC move to MIC
10/11/2011 12:45:14 AM • Lanier VW-160D • Answered on Oct 11, 2011
I HAVE THE LANIER VW 110 TRANSCRIBER; I PLUG IT
Hello is possible that your power supply is bad or may be just the jack on the unit you have two options you can Send an email to [email protected] or call (800) 644-9525. Please indicate model, serial and detailed description of problem or try a new power supply at http://www.tvps.com/Products/Lanier-APS-160-Desktop-Power-Supply---New__LA-APS160.aspx
4/15/2011 4:46:12 AM • Lanier VW-160D • Answered on Apr 15, 2011
Lanier product hand held recorder P-155 is it worth fixing
Hi, It depends on it's value to you. If you need that fixed, you might check the price for repair by calling Geeksquad at 1 (800) 433-5778. Thank you.
10/8/2022 9:12:15 PM • Lanier Audio... • Answered on Oct 08, 2022
How do I erase the tapes on a Lanier VW-210
Press the telephone button first with one finger and immediately after you press that button press the rewind button, The unit should go into rewind and erase should be flashing on the digital display. When the unit starts rewinding take your finger off of both buttons, if you keep them on ,then the unit will rewind and stop erasing .
12/10/2014 1:56:03 AM • Lanier Audio... • Answered on Dec 10, 2014
Lanier p-155 won't turn on
Some times the battery contact need to be pulled out a little bit. they are located down inside the battery compartment. You can stick a small screwdriver under the battery contact and bend it upward for better contact. If that doesn't work try removing the back cover and tightening the grounding screw, which is a silver screw located by the motor pulley hole. Sometimes this screw loosens up and then the ground is lost to the entire unit
12/10/2014 1:51:37 AM • Lanier Audio... • Answered on Dec 10, 2014
Where is the recall button located on the Lanier VoiceWriter 160 transcriber?
It is under the flap located directly under the keyboard buttons. It is a slide switch and you can adjust it for a little recall or a lot of recall.
12/10/2014 1:46:13 AM • Lanier Audio... • Answered on Dec 10, 2014
I have a Lanier Transcriber
This unit most likely has a broken rewind/fast forward rubber belt. This is a very common problem and is easily fixed if you can acquire a new belt. Any place that services Lanier equipment should be able to easily fix this problem.
12/10/2014 1:38:08 AM • Lanier Audio... • Answered on Dec 10, 2014
My Lanier P145 microcassette dictaphone will not pick up when dialing in
Look under the front of the unit and there is a tel ans switch this must be on to enable the unit to answer the call
12/10/2014 1:35:04 AM • Lanier Audio... • Answered on Dec 10, 2014
0answers
0answers
Tape recorder will no longer play or record
Tape players need maintenance often. You have to replace the belt, clean the rubber roller with Rubber Renue, put grease on the odd spot and clean the head by rubbing clean white paper on it. Any electrical contacts like a volume switch etc need a contact spray to remove oxides etc. This should be done every 5 years or even more often if used more often.
11/7/2013 10:38:32 PM • Lanier Audio... • Answered on Nov 07, 2013
0answers
User guide Lanier MS-56 micro recorder
Itrizuto: Did you ever figure this out? I have the same question.
9/7/2011 8:44:26 PM • Lanier Audio... • Answered on Sep 07, 2011
Lanier VW-160D Logo
3 questions posted
Top Lanier Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
Are you a Lanier Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Lanier Audio Players & Recorders
Most Popular Question
own lanier vw 110 transcriber when
  • Audio Players & Recorders
