20 Most Recent
Xcd Dialogue Technology Corp. FlyBook VM PC Notebook Questions & Answers
How can i open my Flybook Vm to change de hardisk
Paolo,
The VM is a very hard machine to work on. You have to start by taking off the battery. Then remove all the screws on the bottom of the case chassis. Once that is done, with the screen extended, carefully run a soft wood chisel or a fingernail around the machine, releasing the clamps on the side of the system holding the plastics together.
Once that is done, you will carefully have to pull away the bottom case from the rest of the system. That will expose your HD and memory.
Lcd connection
It would be uncommon for a laptop not to have a function key, Fn. This would be normally located somewhere bottom left of the keyboard often after the CTRL key and/or before the Windows key. Further, it is often required to press the Fn key + F? key where the F? would be one of the F keys with the small monitor icon.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Como cancelar el winter driver
EnglishIt is a car, and cars are complexbut no car was told , maker, model , and year.we can not guess cars. post the VIN? and all that is knownname a problem what can't your car do right?name symptoms or evidence that is confusing to you.then answers can happen.onlygood luck , finding itand Mucho Gusto.my guess now is this is posted to computer forumand not to CARS !must be some odd traction controls thing'but 10,000 models of cars,
I need a product key
Have you actually purchased Visio, or are you just trying to get it for free?
As a software guy, I would have to advise against piracy. :)
There are several ways to get Visio for cheap. If you are a student, there are discounted versions available online and in stores. Also, you can check with your school for even cheaper options sometimes. Try the university bookstore if available. Or a Computer Science department maybe.
If you are working, and your company uses MS Office applications, find out if they have the "Microsoft at Home" program. You can get MS Office applications for really cheap that way. I can get Visio through my company's "Microsoft at Home" program for a few dollars.
My Employer Says They Are Going To Cut My Wages. Can They?
If you are in the middle of a contract, then cutting your wages is almost certainly a violation of your employment law rights. While I am by no means an expert on this matter, I did have a similar issue years ago - mid-contract wage cuts - and I hired an
employment attorney to fight the case on my behalf. It turned out that my employer was basically looking to scare people into taking the wage cut.
They got into some pretty serious legal trouble for their transgression, and nothing happened to me in terms of wage cuts after that. If you are between contracts, your employer can re-negotiate your salary, but as far as I am aware, if you are in an agreed-upon contract, they cannot just decide to reduce your salary. If you want to settle matters, contest this action with support from a legal professional.
Solitaire master has a hang
clarify pi please. if you meant pi to mean main screen picture, you probably have used up your free time on this program.
