20 Most Recent
Muratec F65 Plain Paper Thermal transfer Fax Questions & Answers
I have muratec F65, i want to adjust the tx/rx
Adjusting the Baud rate is something that a Serviceman has to do....there is no need tho'...your machine is smart enough that when "modem training" takes place each time you place a call..both the fax machines "talk" to each other and figure out how fast or slow they have to work depending on each of the fax machines and the condition of the line in between. They will slow down "if necessary" all by themselves.
Error Code R.3.1
YOUR PROBLEM IS CAUSED BY STATIC ON THE PHONELINE NOT YOUR FAX. BOTH MACHINES TRY TO SLOW DOWN TO UNDERSTAND INTERNATIONALMESSAGE OF FAX COMMUNICATION THEY MUST UNDERSTAND 95% OF MESSAGE OR THEY WILL DISCONNECT YOU CAN TRY NEW PHONECORD 1.00 AT DOLLAR STORE ORCALL YOUR PHONE CO.
Muratec MFX-2725 says there's a paper jam in C1 but I can't find anything
from the picture of the printer, I'm seeing that there are 4 trays to check. Please double check that you've checked all 4 trays and also the back of the printer.
You can also check that you're not using the incorrect type of paper for your printer. If you're using a new type of paper, then this might be the issue. And then you can check the back of your printer as well. Thank you.
