20 Most Recent
Sony VAIO VGN-NS230E/W Notebook Questions & Answers
My sony vaio vgn-ns230e wont
It seems you have corrupted image file.
The best solution to recover it just put another image disk or new installation media.
3/17/2018 4:11:00 PM •
Sony VAIO...
Answered
on Mar 17, 2018
Sony VAIO VGN-NS230E vga
Look and see if it appears as a monitor in your display settings, if it doesn't, then another good first step would be to update your video card drivers (go to
this page and select "Video" then download " Intel Graphics Driver"). If none of this fixes it try the VGA cable with a different PC and see if it works.
10/20/2012 11:42:50 PM •
Sony VAIO...
Answered
on Oct 20, 2012
My laptopt wont let me
Most common thing is to make sure Cap Lock is not turned on. Could be capitalizing everything. Hope this solution helps.
8/8/2012 1:47:52 PM •
Sony VAIO...
Answered
on Aug 08, 2012
How to hook my ns230e to my hdtv
Looking at the spec for that model - you only have a VGA output
On you HDTV do you have a VGA input for PC connection, often HD TV do - if not then we will need the make and model of the TV and type of connections available - also need to check the grahics driver on the laptop to see if it supports TV out via VGA if its to be connected to a different input on the TV
anyway
LETS ASSUME YOU HAVE A VGA input on the TV
TV:- probably has a PC input - which is a VGA connector looks like this http://upload.wikimedia.org/wikipedia/commons/9/92/SVGA_port.jpg and then you select PC input on the TV to display whats connected to that port
Laptop: - Now on the laptop, you will need to select the VGA output to work - there will be a picture of a screen on one of the F keys at the top of the keyboard, F4, F5 normally on laptops, My Sony uses F7 ---- (assuming F7) use the FN key and the F7 key together it will then toggle between the following <laptop only><laptop and VGA output><VGA output only>
3/25/2010 12:47:59 PM •
Sony VAIO...
Answered
on Mar 25, 2010
I am just starting to get a clicking sound in my
Yes, your hunch is correct. This is the hard drive. I would immediately back up your data and, since it is only 4 months old, contact Sony for warranty repair. It could die on you tomorrow, or it could continue to work with the clicking sound for years (I had a laptop just like that).
7/9/2009 2:54:36 PM •
Sony VAIO...
Answered
on Jul 09, 2009
Code error 0xc0000185
Do you the Windows user suffer Error Code 0xc0000185 on your PC or laptop.
Well, this is a blue screen of a ***** error note telling me that your boot configuration info is missing (Error Code 0xc0000185)
This BSOD error code issues with a note - The Boot Configuration Data for your PC is missing some required information.
Causes of Error Code 0xc0000185:-
1. Suffer a cable attachment joining to your system and the hard drive.
2. Defective or missing boot files.
3. The disk drive gets damaged.
4. Wrong disk drive.
Solutions of Error Code 0xc0000185:-
1: Do sure that Wire is Correctly Connected [Only for PC]
2: Automated Repair
3: Check Hard Disk for Errors
4: Repair your System to Fix Error 0xc0000185
Full Solution -
9/14/2022 11:53:07 AM •
Sony VAIO...
Answered
on Sep 14, 2022
Lost video on svt131a11l
Try to:Open Computer by clicking the Start button and then clicking Computer.Navigate to the folder or drive that used to contain the video file, right click it and then click Restore previous versions. https://8ballpool.onl/ https://googlehangouts.ooo/ https://omegle.onl/
9/30/2018 12:52:58 AM •
Sony VAIO...
Answered
on Sep 30, 2018
