20 Most Recent Dell Studio XPS 16 Notebook Questions & Answers
How do I get a meter reading for my copies?
Hi Laura Garcia, Please share the printer model then I can check and let you know if this option is available or not. Thanks and Regards. Kiran Kumar. #iworkfordell.
5/4/2015 6:39:24 AM • Dell Studio XPS... • Answered on May 04, 2015
Broadband not detected
Your wireless may be switched off - Check for a wireless switch or a Fn key that serves this function.
11/29/2014 5:29:11 PM • Dell Studio XPS... • Answered on Nov 29, 2014
Remove speed limiter on 95 buick road master
buy a aftermarket chip
6/13/2012 3:26:52 AM • Dell Studio XPS... • Answered on Jun 13, 2012
Replacing the dvd drive in
Remove 10 screws (back plate)Remove all screws labelled P (as well as black sliding plates)Turn over and remove two screws under these platesremove two screws (bigger than the others) from from top of keyboard.lift full front panel from the back corners (two sticky-out bits on the inner side of the hinges to the screen)Job done
2/2/2012 2:36:05 AM • Dell Studio XPS... • Answered on Feb 02, 2012
How do I get a
I had this same problem. If this is a slot drive.. there is no way in,, so i'm told.I flicked hard / banged the top of the laptop above where the drive is whilst pressing the eject button.Failing this, I would send it back (under warranty) or get a new drive, but I'd assume you'd have to say goodbye to the stuck disc.N.B. I would not recommend to anyone to physically abuse their laptop.. but hey!.. it worked for me!Good Luck!
1/31/2012 1:01:23 PM • Dell Studio XPS... • Answered on Jan 31, 2012
Laptop keyboard not working
reinstall your window.............
1/17/2011 11:26:47 PM • Dell Studio XPS... • Answered on Jan 17, 2011
Hi . thy keyboard on
csivoka, see the solution posted here: http://www.fixya.com/support/t3265538-laptop_keyboard_not_working
It worked for me. I had the exact same problem, which coincidentally, showed up today.
1/17/2011 10:49:18 PM • Dell Studio XPS... • Answered on Jan 17, 2011
Hi . thy keyboard on my xps 16 stop working ... i
exact same issue. just happened today. coincidence?
1/17/2011 10:26:13 PM • Dell Studio XPS... • Answered on Jan 17, 2011
2answers
CAN'T CONNECT INTERNET USING USB BROADBAND TO
try to check if there are requirements that must be met in order to use the usb broadband. try checking the TCP/IP configuration on your network settings. And set it as dynamic.
Because the usb broadband will be responsible in assigning ip address to you so you can connect to their server and use the internet. .
I hope this works
Thank you :)
11/15/2010 5:54:52 AM • Dell Studio XPS... • Answered on Nov 15, 2010
Hi. my laptop keyboard on
There is not so much that could be done to repair a keyboard. Disassemble the laptop, check the ribbon cable connecting the keyboard to the motherboard. If the ribbon cable is loose, tighten it. If it is tight, replace the keyboard with a new one.
10/8/2010 1:56:41 PM • Dell Studio XPS... • Answered on Oct 08, 2010
My dell xps 16 cd
The way to remove and replace the drives is found on support.dell.com under the documentation- generally you can specify the system with the service tag. However, if the system is w/in warranty- you may want to call Dell so you can avoid breaking your warranty I’m happy to help further over the phone at https://www.6ya.com/expert/susan_42b401e0b1603d8a
10/2/2010 9:26:23 PM • Dell Studio XPS... • Answered on Oct 02, 2010
My Dell XPS Studio 16 with Vista 64bit OS
i will recommend returning it if its within warranty period since the only form of making it work will mean a few extra amount of money.
Again this could mean a hardware or firmware error and sometimes a visit to the website of dell or the exact dvd manufacturers website could produce a solution in the form of firmware updates to rectify such errrors. fo try it and all the best
7/4/2010 10:41:16 PM • Dell Studio XPS... • Answered on Jul 04, 2010
Some of te buttons on my keyboard are not working.
Did you recently spill something (coffee with sugar, soda-pop) into the computer?
As it dries out, the sugar starts to conduct electricity.
It's time to take your computer to a qualified technician, to replace the keyboard, because there is no way to "clean" the keyboard.
5/30/2010 6:36:20 AM • Dell Studio XPS... • Answered on May 30, 2010
See the end of this message for details on
Not sure whether this is a Q.
To enable just in time (JIT) debugging, the config file for this application or machine (machine.config) must have the jitDebugging value set in the system.windows.forms section. The application must also be compiled with debugging enabled. For example: <configuration> <system.windows.forms jitDebugging="true" /> </configuration> When JIT debugging is enabled, any unhandled exception will be sent to the JIT debugger registered on the machine rather than being handled by this dialog.
In VS the way to enable/disable that is: 1-On the "TOOLS" menu, click Options. 2-In the Options dialog box, select the Debugging folder. 3-In the Debugging folder, select the Just-In-Time page. 4-In the Enable Just-In-Time debugging of these types of code box, select or clear the relevant program types: Managed, Native, or Script. To disable Just-In-Time debugging, once it has been enabled, you must be running with Administrator privileges. Enabling Just-In-Time debugging sets a registry key, and Administrator privileges are required to change that key. 5-Click OK.
It has to be done by the developer and its his responsible to guide the application error reporting to the system event handlers. If this is an issue which occurs in a certain app, have to check for the .net version (specially in vista). Many 1.0 and 1.1 based apps give the problem. To install dotnet fw 1.1 on Vista will give an error. Most of the time caused by DEP (Data Execution Prevention). But the thing is some software forces the installation of .net framework (older versions). How ever Vista is packed with .net 3.0 and 2.0. Even if you allowed to install will not be able to uninstall 2.0 (possible to remove 3.0 though).
How to solve the installation issue: This issue is resolved in Microsoft .NET Framework 1.1 SP1, however you will need to use the following procedure to install both the .NET Framework and the Service Pack at the same time: Download Microsoft .NET Framework 1.1 Redistributable Package and Microsoft .NET Framework 1.1 Service Pack 1 using links below: Dotnet Framework 1.1 Redest Dotnet Framework 1.1 SP1
Save both installations in the same directory Ensure that the Microsoft .NET Framework 1.1 Redistributable Package is named dotnetfx.exe. If not, change its name to dotnetfx.exe. Ensure that Microsoft .NET Framework 1.1 Service Pack 1 is named dotnetfxsp1.exe. If not, change its name to dotnetfxsp1.exe. Open command prompt as Administrator, and change to the directory where the two installations are saved. Run the following commands using the order shown below dotnetfx.exe /c:"msiexec.exe /a netfx.msi TARGETDIR=C:dotnet" dotnetfxsp1.exe /Xp:C:dotnet etfxsp.msp msiexec.exe /a c:dotnet etfx.msi /p c:dotnet etfxsp.msp Install both Microsoft .Net Framework 1.1 and Service Pack 1 by running C:dotnet etfx.msi
The systems must be backed up before trying this specially the system state. How ever the keys can be repaid in a damage This thread will also be helpful http://blogs.msdn.com/b/astebner/archive/2007/03/26/how-to-repair-the-net-framework-2-0-and-3-0-on-windows-vista.aspx...
5/29/2010 4:37:48 PM • Dell Studio XPS... • Answered on May 29, 2010
My xps 16 i7 the screen changes color red blue
you likely have a bad video chip. Please call Dell if you are under warranty.
5/17/2010 11:11:57 PM • Dell Studio XPS... • Answered on May 17, 2010
Where is a manual to print
The manual for Dell XPS 16 Notebook is HERE
4/9/2010 10:49:55 PM • Dell Studio XPS... • Answered on Apr 09, 2010
2answers
The screen will not come on
I had a similar problem with a one year old Dell laptop, and it turned out that the screen was OK on battery power, but when you plugged it in to the AC charger the screen went very dark. It turned out to be the LCD backlight inverter, which I purchased from a fellow in Florida for about $16 and installed by following the instructions at http://www.insidemylaptop.com/remove-replace-lcd-screen-video-cable-inverter-on-dell-laptops/ . Hope this helps you out a bit...
4/2/2010 12:33:15 AM • Dell Studio XPS... • Answered on Apr 02, 2010
How can i activate the facial recognition
Download the manual from either of these 2 locations. Keep it on your desktop for reference.
http://support.dell.com/support/edocs/systems/insxpsg2/en/index.htm
http://support.dell.com/support/edocs/systems/insxps/
2/21/2010 4:17:50 AM • Dell Studio XPS... • Answered on Feb 21, 2010
My keyboard seems to be locked and will not respond
Press fn key and whichever function key at the top of your board that has a lock symbol on it at the same time. You're in keylock and this will disarm it.
1/28/2010 3:26:40 AM • Dell Studio XPS... • Answered on Jan 28, 2010
Dell Studio XPS 16 Notebook Logo
59 questions posted
Popular Products
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
View Most Popular
Studio Dell
  • Studio Dell
Most Popular Question
thy keyboard
  • Computers & Internet
