20 Most Recent Toshiba Satellite L305-S5933 Notebook Questions & Answers
My FN keys are backwards
Normally you can do that in the bios
9/21/2017 3:17:01 PM • Toshiba... • Answered on Sep 21, 2017
Toshiba L305-S5933 My laptop just wont
Blue screen should give an error number- if it will still start that far. That error code would help you -just search on-line for the error number, but see Microsofts answers, not to get a dodgy answer. I believe the L305 is a Vista base laptop (unless updated). There are a few things you can try- If system restore did not work, it is possible the hard drive has a faulty segment- If you have a vista cd, you can try command prompt from there (scroll down the page to see it) and in command prompt window- type 9apparently 32 bit vista recovery iso is available here https://downloadcenter.intel.com/download/15074/Recovery-CD-for-Windows-Vista- chkdsk /f/r then press enter button-when finished type in EXIT, and the window will close. This will then check and fix any disc errors If it still refuses to boot- Go to command prompt, and type in bootrec.exe /FixBoot For more instruction on this go to https://support.microsoft.com/en-us/help/927392/use-bootrec.exe-in-the-windows-re-to-troubleshoot-startup-issues First the ram- Try removing one at a time, and see if that will work-or, change the ram, or, try the ram in different slot, one at a time.
3/14/2017 7:31:33 PM • Toshiba... • Answered on Mar 14, 2017
None of the Fkeys work when i push them. And yes the laptop is turned on.
Insert your recovery/restore disks and see what happens. If your cmos is set to boot up first off of your optical drive you should get various repair/install options and keys should work.
9/26/2015 3:48:15 PM • Toshiba... • Answered on Sep 26, 2015
Laptop worked fine then shut it down turned it on again & TOSH screen appeared but then screen went black and a blue box came on saying Enter Current P'word. when i did that the laptop turned off.
Last time you used the computer you did something wrong. Of course, computer said nothing but it reared its ugly head when you restarted it! Computers are treacherous - they bite you when you least expect it - women are more predictable. See if you can boot up by hitting the F8 key and selecting " last setup that worked" option. Do you have restore disks? If so use them to go back and possibly repair the OS. Also check with Toshiba for any other options. If nothing you just might have to reload the unit from scratch using the restore disks. If you never made them as advised then you are really scr--d. Either you buy the disks from Toshiba or you borrow some friends)S disks and do the deed.
9/26/2015 3:19:51 PM • Toshiba... • Answered on Sep 26, 2015
Black screen won start
Look for a brightness up/down arrow in the F1 - F12 buttons on top of your keyboard. Try tapping on the up arrow for brightness, also try tapping it while holding the Fn (function) key of your keyboard. If it seems like no power is going to your screen, you may need a new screen or a computer technician to look at it. If someone you know is good at hardware, have them check the power connection before paying a store or technician.
2/7/2014 5:42:29 AM • Toshiba... • Answered on Feb 07, 2014
0answers
2answers
Toshiba at the rate and invertd comma keys are interchanged
Dead easy, go to the Control Panelselect region and language settings.
On opening you will get a pop up with 3 tabs
!st tab change region to UK
2nd tab click details and change all options to UK
That's it done.
8/29/2013 3:45:35 PM • Toshiba... • Answered on Aug 29, 2013
Sound system in l305-55933
You can download the audio and device drivers for your model laptop from the Toshiba WEB site from their download page. Make sure you enter the model of your laptop so you can get the correct drivers. Please click on this link: - http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp
3/30/2013 5:16:53 AM • Toshiba... • Answered on Mar 30, 2013
Toshiba Satellite c655 is only showing blue screen after powering up.
Could you describe what it shows? Usually it shows something like STOP or similar words. A picture would be even better
1/6/2013 12:57:52 AM • Toshiba... • Answered on Jan 06, 2013
Bootmgr is missing
To repair missing corrupted system file/s, boot up with the Windows installation CD then -Press R to repair wheninstructed.Press 1 or Enter to repairthe C:\Windows folder.Then type chkdsk /r and then press Enter.The repair process will takequite a long time.
6/25/2012 6:47:15 AM • Toshiba... • Answered on Jun 25, 2012
Satellite L305-S5933 ethernet
Get onlineand got to www.google.com In the google search box type: "ToshibaSupport" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operatingsystem when requested. Download and install the Network drivers.You can also try Driver Guide.http://www.driverguide.com
5/11/2012 5:22:37 PM • Toshiba... • Answered on May 11, 2012
Why is my toshiba blue screening
You may have a bad device driver, or you have virus in the system, run a full scan with your anti-virus, and download malwarebytes anti-malware from www.download.com
5/7/2012 8:59:13 PM • Toshiba... • Answered on May 07, 2012
User profile wont charge
LOL, what do you mean by user profile wont charge?
4/7/2012 1:17:03 AM • Toshiba... • Answered on Apr 07, 2012
Web Camera not responding
Go to www.google.com and in the search box type "Toshiba Support". Look for drivers and downloads. When you are on their site you will need to give the model number and operating system in order to get the correct camera driver. Download the driver and install it. Another option is to click Start/Control Panel/System or System and Performance and get into your device manager. Look for Imaging Devices or Input Devices and you might see the camera. If you do right click on it then select properties, then you can select the option to update driver. If all fails and you need a simple application program and driver to use your web cam. In google search box type "download.cnet.com" (without the quotes). Click the link provided to go to the site download.cnet.com and when it opens look to the left side of the window you'll see a gray area that says "Find Software". Type in: Manycam and click the search mirror. The next page will bring you the findings of the search and Manycam is the second one on the page. Click the Download Now just to the right of Manycam and download and install it. Be sure to uncheck and decline any offers for buggy toolbars or any other junk they want to put on your system during the install process. All you want is Manycam. It's fast and simple to operate.
3/22/2012 11:30:02 PM • Toshiba... • Answered on Mar 22, 2012
Toshiba laptop stuck on Microsoft Corportation screen
not to sure how that can be fix for its very important to have the updates done for it updates the system and it is required to let the process finish. Take your computer to a shop and they will be able to help u but do not ask how much it would cost. :)
2/19/2012 6:20:43 AM • Toshiba... • Answered on Feb 19, 2012
3answers
Forgot my password
Remove/reset lost Windows password you can use Windows Password Rescuer, it can reset/remove Windows 7/vista/xp/2008/2003/2000 password instantly.1_17_2012_11_56_25_am.png I highly recommend [Daos Password Recovery Bundle 2012].[Daos Password Recovery Bundle 2012] is an all-in-one password recovery software, which recover password for Windows, Excel, Word, Access, PowerPoint, Outlook, RAR/WinRAR, ZIP/WinZIP, PDF etc. Over 70+ types of passwords can be recovered instantly.1_17_2012_11_56_54_am.png
1/17/2012 12:24:16 PM • Toshiba... • Answered on Jan 17, 2012
Toshiba satellite l305-s5933 cant access bios and wont boot
If you want to reset the Toshiba BIOS , You can try visiting this web page..http://web.archive.org/web/20080821232354/http://www.11a.nu/software/bios-pc-bios-security-and-maintanance-toolkit/: Run the DOS executable ..: And most of the BIOS password resets are done using the same ..You can try..
1/6/2012 9:37:58 PM • Toshiba... • Answered on Jan 06, 2012
I cannot pay by credit
Look for a service or local bank that can create for you a Master Card or Visa "Debit" card. It looks just like a "Credit" card, but you have to deposit money into an account and only use that money. A debit card can then be used like a credit card as long as there is money in the account.
If you are working for a company, I recomend this company http://www.payoneer.com/
your employeer can set it up and get you a card. When you get paid, your money goes directly into your card account. I use it... I live in a "Foreign" country also.
8/25/2011 10:49:31 AM • Toshiba... • Answered on Aug 25, 2011
Toshiba Satellite L305-S5933 Notebook Logo
68 questions posted
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Satellite Toshiba
  • Satellite Toshiba
Most Popular Question
forgot password
  • Computers & Internet
