20 Most Recent
Venturer PLV36220CS5W-DC LCD TV Questions & Answers
Venturer tv has no picture
If the audo [sound] is OK; back-light problem.Check and replace damaged component/s at its
back-light inverter board, or replace this board as card basis.If you wish to get some details; check the site linked here.Surf the site with patience.Pull up older posts.
It will be best to replace the inverter board as card basis.
8/4/2014 1:26:32 PM •
Venturer...
Answered
on Aug 04, 2014
Are your under cabinet mounted TV's Dish network
We would be happy to help you with getting your DISH Networkremote to control your Venturer TV. We currently do not have any codes for the brand Venturer so we would need to perform a power scan. A power scan will scan your DISH remote for any codes that will work with your TV. Here are the steps for a power scan:
Step 1:
Press and hold the TV mode button until all mode button back lights illuminate,then release.
Step 2:
Press and release the Power button.
Step 3:
Press the Up button once a second while pointing the remote at the desiredequipment. If the code for the equipment comes up, the equipment will poweroff.
Step 4:
Press the pound (#) button. If the code entered is valid for the remote, themode light flashes three times.
After doing the power scan please remember to put the remote back into SATmode. Thanks so much for being a valued DISH Network customer!
Phillip Chang
DISH Network Customer Service Representative
2/25/2011 8:20:49 PM •
Venturer...
Answered
on Feb 25, 2011
Where can I find a replacement monitor cord for a Venturer PVS1961?
It may be difficult to find a replacement monitor cord specifically for the Venturer PVS1961, as it is an older model. You can try searching online for "Venturer PVS1961 monitor cord" and see if any results come up. If you're unable to find a replacement cord, you may want to consider purchasing a universal monitor cord that can be adapted to fit your device.
It's possible that you are missing other cords, such as a power cord. It is best to check the manual or contact the manufacturer to see if you are missing any other cords.
1/22/2023 4:36:58 AM •
Venturer...
Answered
on Jan 22, 2023
Where can I get the hinge replaced on a 15.4 Venturer tv KLV3915
Please call geeksquad at Bestbuy to setup a repair appointment. There phone number is 1 (800) 433-5778. You can mention the tv model that you've mentioned here and they should then confirm their ability to repair the hinge. You might have to email a picture in so that you don't have to carry the tv to the store. Geeksquad might even be able to pick up the tv for you if they determine that they can do the repair.
Thank you.
10/10/2022 11:04:39 PM •
Venturer...
Answered
on Oct 10, 2022
