20 Most Recent
Polaroid FLM-1514B LCD TV Questions & Answers
My TV turns on, has a blue screen but won't
Now tv turn on,tv get a picture only flashes few sec.than died have sound left only?Yes,than the tv long board call the LCD inverter board is dead.This long LCD inverter board help the LCD screen panel to have a backlight to produce a picture.Tries websites like Shopjimmy.com,Ebay.com to buy a long refurbish LCD inverter board for the replacement.
11/20/2010 7:36:19 AM •
Polaroid...
Answered
on Nov 20, 2010
I'm trying to connect my Polaroid 15
Turn off blue screen in the menu of the TV if you can or cycle through the input sources on the remote to find the directv signal. Check cable setup in back of TV if it still does not work. Has the directv box been working with any other TV?
7/30/2010 4:47:17 PM •
Polaroid...
Answered
on Jul 30, 2010
No picture
Check to make sure your selected inputs are correct ( ie cable, TV, antenna, VGA, etc).
Next, go to "menu", then "Settings", then "Factory Reset" and see if that works.
You might try to run the auto channel setup as well.
If none of these work-- or if you end up with audio but no video-- then your TV is junk. Polaroid will offer you a repair service for a flat rate of $100 if you ship the TV to thier facility in NY at your cost-- but that's not really cost effective as the TV only costs $150.
Personally, I'm done with Polaroid products-- they just don't last much more than 2 years.
10/9/2009 6:47:30 PM •
Polaroid...
Answered
on Oct 09, 2009
Polaroid TV working with constant red flashing light
If your Polaroid Roku TV is working fine but the red light is continuously flashing, it could indicate an issue that may need attention. Here are some steps you can try to troubleshoot the problem:
- Power Cycle:
- Turn off the TV and unplug it from the power source.
- Wait for at least 5 minutes.
- Plug the TV back in and turn it on.
- Check Remote Control:
- Ensure that there are no stuck buttons on the remote control. Press each button to make sure they are not stuck in the pressed position.
- Update Firmware:
- Check if there is a firmware update available for your TV. You can usually find this information in the TV's settings menu.
- Reset to Factory Settings:
- Perform a factory reset on your TV. This will erase your settings, so be sure to back up any important information first.
- Check for Physical Obstructions:
- Make sure there are no physical obstructions around the TV, particularly around the infrared sensor on the TV and the remote control.
- Contact Customer Support:
- If the issue persists and your TV is still under warranty, consider contacting Polaroid customer support for assistance. They may be able to provide additional troubleshooting steps or offer a solution.
- Professional Repair:
- If the TV is no longer under warranty and the issue persists, it might be advisable to consult a professional technician or a TV repair service to diagnose and fix the problem.
Always refer to your TV's user manual for specific instructions related to your model. If none of the above steps resolve the issue, it's recommended to seek assistance from the manufacturer or a qualified technician for further diagnosis and repair.
12/27/2023 10:15:57 PM •
Polaroid...
Answered
on Dec 27, 2023
