20 Most Recent
Electrolux Frigidaire Affinity AGQ8700F Dryer Questions & Answers
On autodry clothes do not fully dry
Try it with the exhaust pipe disconnected for a load, if that makes a difference, you need to have your vent pipe cleaned. Check in your exhaust pipe in the machine, too.
My Electrolux dryer is throwing the code ehi
That is not a standard code. You won't find it on the Electrolux site. I can infer nothing from that. You can either try the general troubleshooting tips for Electrolux dryers OR try to contact Electrolux customer support. Since I have no access to whatever this code means, I can't assess the problem. Here is a troubleshooting video for Electrolux dryers:
https://www.youtube.com/watch?v=5dDqrB3nk2s
Electrolux Dryer screen went blank
I am not sure what your Dryer model is or its age but it could well be that there is a plug loose on the main control board or some fault on the wiring inside the top behind the display panel.You could check to see if this is the case but make sure the mains power is off first,remove the top lid and check,or It would be best to get in touch with Electrolux to see if a repair is covered under the Warranty.
Hope this helps.
Good luck.
What does e62 mean on an Electrolux clothes dryer
This error code indicates the water is overheating during the wash cycle. The first thing to check is if the water inlet hose is connected to the cold outlet and not the hot one. If the hose is properly connected, the temperature sensor will need to be checked and if faulty, replaced.
