20 Most Recent
Pitney Bowes 9920 Plain Paper Fax Questions & Answers
Pitney Bowes Manual for AD20
I
have this manual on my computer. If you send an email to
[email protected] I will send the manual to you right away.
Please put PITNEY 9920 as the subject line. I hope that this will help you out. Lawrence Brown
Pitney bowes 9820 fax machine is popping up error
Error 50 is a service error and you will need to contact your local computer repair or go to their
site and talk to customer service to get someone to fix this for you.
Hope this helped
Positive Feedback ALWAYS Appreciated :)
How do you set the time on a 9910 PB Fax?
You need to go into Set Mode and User Parameters
To do this press Function key and 7 to get Set Mode
Then press 1 for User Parameters and set, the first option is to set date and time, use the number pad to do this.
Incoming faxes are black, except for 1
Have you replaced the image unit lately? The toner disposal section of the cartridge fills up and then spills out causing this problem. The interior of your machine is probably caked with toner also, so when you replace cartidge, you need to clean inside machine also.
I have a paper jam on my Pitney Bowes 1630. The
Good Luck, When the paper is stuck in the back, it is in the fuser and you may be able to get the paper out, but probably the drive for the fuser is messed up, which caused the jam in the 1st place, if you get the paper out, the next one through will probably jam up again. Technicians usually just replace the fuser. Oce is the repair entity for these machines now. 1 800 2423 5556
