20 Most Recent
La Crosse Technology Radio Controlled Post Office Regulator Clock Questions & Answers
How can I get my clock to chime the right time? It is always one hour too much.
- First see if changing the time with the battery out changes the time without changing the cycle on the chime - I could just imagine somebody adjusting the clock for daylight savings and the clock doesn't change it's chime cycle correctly with the battery a certain way - in or out - maybe it's the opposite and you have to take the battery out and somebody didn't now you have to leave it in.
- Check the internet for the original manual if you know the model.
- Look for clues to setting the chime on the back? is there a separate knob - are the batteries both good?
Still not working after playing with it? Here is the mechanical way to fix it:
Sounds great, but it still is chiming the wrong time after playing with it? This will fix it:
- Set the clock for exactly at the chime - I suggest 3 o'clock chime - the hands will be wrong (2 or 4 or whatever)
- Remove the battery(s) - I do custom imprinted clock faces and it seems to me that 3 o'clock is the easy place for me to put the hands back.
- Take the clock apart - usually it is tiny screws on the back, or you will see 3 or 4 v shaped wires. push the v wire out of one side - they are springs that some clocks use to hold the rim instead of the screws - they are easier than they look - just pull one side and remove.
- Gently pull up each hand off the shaft. I hope you have fingernails.
- Replace the hands back at exactly the time that they are supposed to be (3 o'clock in my example) - you start with the hour hand and gently push on the spindle make it look level and all the way on - then the minute hand at 12 also level
- Remember to play with the time first so you'll be happy that you put the hands exactly where the chime should start.
- Remember to make that time be exactly on the hour with the small hand and exactly on the 12 with the big hand so the hands line up correctly.
11/9/2015 10:51:19 PM •
La Crosse...
Answered
on Nov 09, 2015
Hi we need a manual
Hi Linda, i have the same 1983 Travelaire motorhome Econoline F-350 26ft and are in search of the Shop/owners manual ... Do you know where to find one ?
I am located in BC Canada
Reg 250-379-2971
[email protected] if you can contact me ?
How can I maintain my pool table at top condition?
In
order to maintain the condition of your table and prolong its lifetime you
should avoid eating above the table, putting drinks of ash trends on the sides
of the table, and generally try not to harm the cloth with the cue. In addition
you can clean and vacuum the table from the outside once a month, this Is what
I'm doing to my table.
What is the price range of a quality foosball table?
Good quality and long-lasting table start at
about $600. In this case, like in many others, the more you pay, the better
quality you will get. Make sure that you're buying a known brand and compare
prices first, before you buy. It is also recommended to read some reviews about
a table or tables that you like.
How to repair tent trailer roof
Go to an auto parts store and buy a fiberglass kit. Resin, hardener and cloth. Clean and rough the area. apply a coating of mixed resin, then a layer of cloth. Let it dry and repeat a couple of times. After you are satisfied with that get a gallon of Elastomeric, you will find it at Lowes/Home depot. Clean the entire top and apply 2 coats with a brush or roller about 24 hours apart. No rain or moisture for a couple of days. Project complete, water proof roof.
I'm in my 50's, can I start playing table tennis?
Definitely! You should know that Table tennis is asport for all ages, and it is never too late to get started. You should know that in the year 2008, Olympic table tennis canbe called the Veteran Year as 38 year old
Gao Jun and34 year old
**** Chendirectly qualified for the 2008 Beijing Olympic Games on the women's side. Andon the men's side, 45 year old
David Zhuangwon the right to attend the Olympic Games as the USA' sole male representative.
I have been playing tennis for a few years now in
If
you are undergoing coaching, then you already are following a tennis specific
program. But the intensity of your training depends on the level of tennis you
play. To further improve your fitness, you could try to go to some tennis
coaching centre or clinic of repute that provides a tennis specific training
regimen. They would have a program that would help improve your technique,
breathing, endurance, etc. Depending on their quality, they might have trainers
who could work with you individually to help identify your strengths and
weaknesses. As far as improving your court coverage is concerned, a good
training centre apart from the normal training might provide separate
athlete agility training programs that can be custom suited to your needs. There
could be several such centers in Mississauga and Toronto.
