20 Most Recent
ASUS PG221 22" TFT LCD Monitor Questions & Answers
Where to find new power supply board (EADP-86AF B) for ASUS PG221 monitor
Instead of replacing the whole board, look for bulging (top) or leaking (bottom) electrolytic capacitors. Usually the failure is one or more of these inexpensive components which you can order from Digi-key.com and have delivered next day.Try to stick to the correct value (uF) but you can go over voltage. do NOT go under voltage. for instance you can replace a 1000uF 16V cap with a 1000uF 50V cap, but not with a 10V.
Hi Support
I hope you can
From your description of the problem, I would suggest that the issue is not with the inputs, but with an internal fault. The fact it powers up then cuts off is symptomatic of power capacitors failing, or could be due to a faulty circuit component on the internal board. For reasons of safety, I'd strongly suggest that you take this to a qualified engineer for more accurate analysis and repair, rather than attempting to trace the fault yourself. Check also the main power lead and socket on the monitor and substitute it for a new one to test it.
I'm also assuming you tried this monitor on another computer? A failing graphics card or chip would also give you the problem you describe
My Asus PG221 monitor suffers from frequent issues
I'm afraid this looks like an electronic fault. Some component, most likely a capacitor, has degraded, is overheating and going out of spec.
You just might be able to squeeze some more hours of work - but the monitor is still likely to drop dead any moment now - by rigging a computer fan on the backside to extract hot air from the inside.
Possibly, the problem might have a noise factor - try adding a ferrite shielding on the cable (unless one is already there, as it often is) and see whether the thirty minutes' grace period extend somewhat.
A probably unsatisfactory solution might be to drive it at a lower resolution, so that the more relaxed frequency constraints do not stress the component so much.
When the capacitor finally blows, you might be able to recognize it and have it replaced; it's likely a US $1 component and is probably in the LCD driver section. Perhaps, just perhaps, you could already be able to see it with the naked eye looking for a component that looks "wrong" - a small cylinder that looks bloated, with electrolyte leaking, whitish powder around the base, etc. But you would still need some solder work to get it replaced - and, if it's a SMD component, chances are it can't be done at home.
Sorry for the bad news...
I dont have a installation disc
go to manufactor web site, download driver for your operating system and exact model of monitor. after that, go to display properties in settings then advanced to change driver.
How do I enhance my Asus PadFone X mini speaker loudness?
Look for a program called Sound Booster or one called DFX. DFX is my favorite because it not only boosts the volume, but lets you add other effects to enhance you sound as well. There is a free version. but to get all the effects you have to upgrade to the paid. If audio is important to you, check it out.
How to fix sound is not working in my asus laptop?
Try going into sound select and test reinstall driver off Asus website..if you installed new windows or update drivers may not work right...see if you can roll back driver in device manager ..if not lookup your laptop model and reinstall...
Graphics card no picture on monitor when connected via HDMI or any cable?
The issue you are experiencing with your graphics card and monitor can be caused by various factors. Here are a few troubleshooting steps you can try to identify and resolve the problem:
1. Check power connections: Ensure that the graphics card has the necessary power connections properly connected. Some higher-end graphics cards require additional power connectors, such as 6-pin or 8-pin PCIe power connectors. Make sure they are firmly plugged in.
2. Verify BIOS settings: Access your motherboard's BIOS settings and check if the primary display output is set to the PCIe slot where your graphics card is installed. It should be set to prioritize the discrete graphics card instead of the integrated graphics (if applicable).
3. Update BIOS and drivers: Visit the Gigabyte website and make sure you have the latest BIOS version installed for your motherboard. Additionally, download and install the latest drivers for your graphics card from the XFX or AMD website. Outdated firmware or drivers can cause compatibility issues.
4. Reset BIOS: Try resetting the BIOS to its default settings. Locate the CMOS battery on your motherboard, remove it for a few minutes, then reinsert it. This action resets the BIOS settings to their defaults and may resolve any conflicting configurations.
5. Check for physical damage: Inspect the graphics card for any physical damage, loose connections, or faulty components. Ensure that it is securely inserted into the PCIe slot and that there are no visible signs of damage on the card or its connectors.
6. Test with a different monitor and cable: Connect your graphics card to a different monitor using a different cable (e.g., DisplayPort, DVI) to rule out potential issues with the HDMI cable or the monitor itself. This helps determine if the problem lies with the graphics card or the specific combination of monitor and cable.
7. Check for motherboard compatibility: Verify that your graphics card is compatible with your motherboard. Check the manufacturer's website for compatibility lists or consult the user manual for your motherboard. In some cases, a BIOS update might be necessary to ensure compatibility.
8. Seek professional assistance: If none of the above steps resolve the issue, it's advisable to contact the technical support of your motherboard or graphics card manufacturer. They may have specific troubleshooting steps or recommend further action, such as warranty service or component replacement.
Remember to handle your hardware with care and take necessary precautions, such as grounding yourself and disconnecting the power supply, before performing any physical checks or adjustments.
I am using an Asus Vivo mini computer approx 5 years old. Since December I often receive error message across top, "Microsoft Edge (not responding)"
Question edited for clarity and toss in a load of CAPS as needed.
Microsoft Edge is one of the worst browsers ever invented. It is flashy and looks pretty, but is not user friendly and is glitchy.
The most likely issue for that Error Message is your Internet Wifi signal dropping out. You can test this theory two ways.
Do you have a smartphone? Download the Free App Speedtest. When you get the Edge Error, whip out your phone and do a Speed Test. If it stalls or only returns a speed of 5 to 10 mbps, that is your issue.
Or Download Google Chrome which is FREE and a much more robust browser and easier to use. Keep both Edge and Chrome open, when Edge collapses, try to do things on Chrome. If Chrome works, then the issue is Edge. If Chrome also fails, the issue is your Wifi and Router. A Router reboot should be done about once a month.
Google Chrome Download - Download Google Chrome
google.comhttps://www.google.com
Continue your browsing experience from desktop to phone on Chrome. Download today. Now more simple, secure, and faster than ever - with help from Google built-in. Google Address Bar. One browser, all devices. Type less with autofill. Chrome support.
Download Now
Get a new and fast web browser. Download Chrome and start browsing.
