20 Most Recent
AOC 19" LCD HDTV Monitor Questions & Answers
LCD monitor flashes on and then go black
hi
try to reconect the main power cable first and then conect it again if the problem solved good and if not the problem is in the power supply capacitors not good.
I HAVE 2 CABLES WITH
The description you have provided does not say what the cables are or for. The best I can get from that is a vendor based gauge and rating more than an actual model or part number. If you could tell the shape of the connectors including pin count, row count, pattern, location of any key pins (key pins tend to be plastic or metal blockages which insure proper insertion alignment), or whatever else you see on the connectors, that would be a much greater help in figuring things out.
USB port not working
Sometimes i know you have to plug in a usb from the monitor to the computer. If this is already done simply unplug that usb device and plug it into another usb slot on the computer itself. If this does not work try replacing the cable. If that does not work try testing by plugging in something on the computer to make sure the usb ports work and then try in monitor, if it doesnt work in the monitor then something went bad with the monitor. Check for warranty. Same with computer if it doesnt work.
- please vote for me :D
My aoc 18.5' s osd
unplug the monitor from the power cord. wait two minutes, plug it in again. this will most likely reset the monitor to it's default settings.
Power locked
Get a power strip use t, apparently your switch is broken, be lad it's on instead of off.
For approx $3 you have a solution.
I almst never use por button, power strip, disconnects all poer to monitor etc. power strip w/high quaity surge suppressor recommended
AOC i-menu downloaded but does not work this is a new monitor E2270SWHN 21.5 inch
- Try Reinstalling: Sometimes, software issues can be resolved by simply reinstalling the program. Try uninstalling the AOC i-menu software from your computer and then downloading and installing it again from the official AOC website.
- Check Compatibility: Make sure that the version of the i-menu software you downloaded is compatible with your operating system. If you're using Windows 10, for example, ensure that you've downloaded the version of the software designed for Windows 10.
- Update Drivers: Ensure that your monitor drivers are up to date. Sometimes, outdated drivers can cause compatibility issues with software like i-menu. You can usually find driver updates on the AOC website or through your computer's device manager.
- Contact Portrait Displays: Despite the difficulty in reaching them, continue trying to contact Portrait Displays through the link provided by AOC support. You can also try reaching out to them through their social media channels or any other contact information you can find online.
- Check Community Forums: Sometimes, other users might have experienced similar issues with the i-menu software and found solutions on community forums or discussion boards. Try searching online for any threads related to your problem and see if there are any suggested fixes.
- Alternative Solutions: While waiting for support, consider alternative software solutions for adjusting your monitor settings. There may be third-party software available that can provide similar functionality to i-menu.
Ik heb scherm met windows 10 desktop computer aoc locked
On the Windows 10 login screen you will need to press control,alt,delete and press and hold down the alt key and release the delete and then finally release the keys then,
Now enter your ID and the password.
You will need to press the enter key or click on the right arrow button.
How do i adjust the brightness
please look for a button with a sun icon above it. Usually pressing that button and the using the corresponding arrows on the device should allow you to alter the brightness.
Thank you.
