20 Most Recent
HP Pavilion dv5-1004nr Notebook Questions & Answers
Lap top gets so hot it burns my skin
As for the overheating cause, I can only say if you've ever added on hardware to it maybe the current fan is inadequate for the job. As a solution I would see about getting an upgraded, fan. Or buy a cooling stand, they plug into a USB and your laptop sits on top of it. Hope this helps.
My HP pavilion dv5 1004nr
Silicon will bridge the gap between the CPU and the heatsink, but this will not have any thermal transfer properties. You should first of all see why the heatsink and CPU did not meet and why there was a gap. Under the heatsink and on top of the CPU there should be thermal grease, and above the graphics chip, there should be a thermal pad, it looks like a blob of blu-tack, if this pad is missing, it will not allow heat to transfer between the graphics chip and the heatsink and eventually destroy the chip through overheating. if you have got this working using silicone, you will find it does not last for long. If it is shutting down now, it is due to overheating
I'd strip the laptop down, find out what is causing the heatsink not to sit firmly on the chip (is this the right heatsink and fan for this laptop)? Clean and regrease the chip and area on the heatsink on which it sits and gently tighten up the spring loaded screws in sequence.
Clean off all the silicon and make sure there is a thermal pad on the graphics chip (may also be one one the southbridge too)
Laptop won't boot. Caps lock
Don't restore the system to a hard disk of different size. You may fix the old disk again and use it while using the new (probably larger) disk as an external disk (by fixing a driver bay).
If you want to use the new disk you will have to install the operating system and software from scratch.
Video goes haywire and wont
Not possible,
1) Please check video card whether is it shared RAM.
a) it is possible that your RAM is spoiled too, change another RAM to try
2) if under warranty, bring back to brand vendor
When I play game such
To avoid laptop overheating, follow the information from this
link, or you can get a usb cooling fan to help cooling it off while playing.
No sound on my machine. Cannot hear any sound
check if your sound settings is not MUTE
check your audio device status in device manager
- look for my computer icon, right-click then PROPERTIES
- select HARDWARE > DEVICE MANAGER
- check if audio device has "?" or "!"
- click refresh button or update driver
Tab and A keys stick
try this- remove power from the laptop and put some alcohol in between the keys near the tab and A
When I shut down my HP Pavillion dv 5 1233 se, the
To reinstall power management in windows Vista operating system:
1) Click on start and type device manager in search field.
2) Click on device manager in the list.
3) Click + next to system devices.
4) Right click on folowing controllers and select un install one by one. Uninstall only the options that are available in the notebook from the following options.
a) ACPI Fan
b) ACPI Fixed feature button
c) ACPI Thermal Zone
d) ACPI compliant system
Restart your notebook after uninstalling all above controllers from device manager. Operating system will install new drivers automatically on restarting notebook.Then need to install the latest BIOS for your notebook model to get rid of the issue.
Wireless button doesn't work
Maybe your internal switch are broken, and your external control does not work, you need to open your laptop and see if this is really what happen in your laptop.
We can fix your wifi for $59 usd
10001 buckwood ave 79925 El Paso Tx.
Contac us if you are interested
Thanks, please leave feedback
Vcrtech
support@vcrtech
[email protected]
www.vcrtech.com
Removing virtual drive
It depends what program you used to add it in the first place. Open the software and look for settings, or just uninstall it.
What causes a red screen when starting up?
no pc told, Pavilion means zerothat name is is used on desktops and laptops for agesthe HP has diagnostics so run those. HP.com tells how.not told desktop or laptops. just 1 word."Screen"first Pavilion was 1995
What does a HP laptop notebook with model number A6Y530A look like
learn to google mate.
this is no secret,gee millions sold.
A6Y530A
the partsurfer shows true model, and fails
this is the only post here ever asking for reverse code lookups
on models fake, and is not easy in vast cases
I guess you have no such PC, (look like)
so why ask this>? what prompted this quest>? not told
why not ask seller for photos of it if this is a pre sales question , is it>?
google and bing and HP all show that model # is BOGUS
so go back to your sell and ask the we can not guess PCs ever.
HP product ID# is best on the service tag for SURE.
where did you see this number, not told.
or that number is some 20+ year old COMPAQ PC ,lost in the sands of time, and no google hits.
you posted to HP forum, (not real) Hp.com is real
