20 Most Recent
Acer Aspire 5920-6335 Laptop Questions & Answers
Hi im having acer aspire 5920 laptop... the
When you get it to boot, run CHKDSK/F or Scandisk straight away to try and fix any errors before you find you are unable to get to your files anymore.
Make a backup of your data before it is too late!
When power charger is connected, screen goes
You could have the battery settings wrong.
Go to Control Panel, Change Battery Settings, then Change Plan Settings of whichever plan is selected. Once there, set your display brightness for when the charger is connected to maximum with the slider. While there, you can also set the display brightness for when the battery is connected.
Good Luck.
Pointer not showing
IF you can get a USB mouse, plug it in, and see if the pointer shows up.... IF so, you can go to the next step... IF not there is a major issue.
IF you do see the pointer, look along the top of the keyboard for a "f-key" that looks like your touch pad (it may be just a rectangle), press and hold the "Fn" key (found along the bottom of the keyboard towards the left side) and then press the "f key" the you found along the top, then release both keys together...
Hope this helps.
How do i use shift key
Shift key is the first key on the second row from the bottom in the keyboard.
CompQ
0xD000001E
Acer Worldwide Support This issue has to do with errors in Acer's recovery software. If you need to use their recovery disc, you need to contact Acer in your region. If you don't, use an OEM or Retail version of Windows and do a "clean install".
Hp 2509m fflickering
I have a good idea of what it may be, problem is there is HIGH voltage inside, and there are NO USER SERVICEABLE parts because of this.Meaning I don't want you to get a BAD to FATAL shock, in attempting to repair.(The are Capacitors inside that store a charge for weeks, months, many times OVER a year.Some of those 'caps' are rated to handle Up To 100 Volts )Which is cheaper?Replace monitor, or get a new you?Oh that's right. YOU CANNOT be replaced.
http://www.badcaps.net/forum/showthread.php?t=24866Be safe, live long and prosper.Regards,joecoolvette
