20 Most Recent
Seiko S149 Stopwatch with Built In Printer Questions & Answers
Seiko Stop Watch S149
If you go to "www.sportscounters.com/seiko-s149-stopwatch-printer-all-in-one" you will see a telephone number, try calling them for advice.
(This problem is fairly common after replacing batteries, so I suspect that there is a procedure for resetting the timer.)
I replaced both sets of
I'm assuming that you have the correct thermal paper and it was installed correctly as explained in the manual at page 7.
If this is the case then the defect is hardware. To find out where the defect is located you must do a simple test by pressing the paper advancing switch. If the paper doesn't move then the paper mechanism has failed and it will have to be replaced - only a Seiko dealer can do that since they are the only ones that have spares, you will have to send it to one. If the paper moves then the defect is in the print unit - there are no spares for it, the unit is dead.
How do i get the
I suggest taking the item to a watch repair store and have them install it for a min. cost, some will change the battery right on the spot. The other option is to get the proper tool called a case opener that will take the watch case off. go to
www.ebay.com and type watch tools, there you will find all kinds of case openers that have fixed sizes and adjustable ones.
