20 Most Recent
Toshiba Samsung TS-H943A Replacment DVD drive for XBox 360 DVD Drive Questions & Answers
Had hitachi drive, installed samsung drive. Now it
If you had a Hitachi drive you need a Hitachi drive to replace it, unless you want to get into very complicated stuff and messing with firmware, etc.
You can get a Hitachi drive for about $28 from this site: http://parts.consolerepairguy.com
All you have to do is put the old circuit board from the DVD drive (open it up and take it off of the bottom) into the new DVD drive.
Hope that helps!
Replaced xbox 360 dvd drive not read
Ok the problem is all xbox 360 motherboards come with preset keys like
a password everyone is different. your origanal samsung dvd drive
also has the key programed into its sst chip on the pcb (Printed Circut
Board) which allows it to work with that motherboard (another way of
explaning this is it works the same way as a wireless network anyone
can connect to it but you must input the correct password to be able to
connect and use the internet)
There is a solution you need to
extract the dvd key out of your old dvd drive and inject it into your
new one. To do this you will need a few tools
Xbox opening Kit V2
CK3 Pro Connectivaty Kit
Via Sata Pci Card
Jungle Flasher Software.
I
Repair xbox 360's and have repaired 100's please visit my web site at
the address below you can find all the software, hardware and guides
needed also if you view the guide it shows you how to flash your dvd
drive to enable you to play backed up games.
www.RightPricedElectrical.com
please rate my soloution
Toshiba washing machine model AW-DK1700WMM has turn on, beeps with error code EL then shut down within 5 seconds, how can I slove this problem?
To fix the EL error code:
* Make sure the door is completely closed and latched securely. A loose or broken latch can cause the error.
*Examine the door lock for any damage, dirt, or debris that could prevent it from working properly. Clean the area thoroughly.
* Turn off the washing machine, then unplug it for a few minutes. Plug it back in and restart it. This may resolve communication issues that trigger the error.
* Examine the wiring connections between the door lock system and the control panel. Faulty connections, such as loose or damaged wires, can disrupt communication and lead to the error message.
3/26/2024 1:48:19 PM •
Toshiba...
Answered
on Mar 26, 2024
How to fix tablet toshiba wt8-a
Ensure the cd rom is empty and the bios is set to boot from drive C first, then drive D.
If all in order and it still doesn't boot, try a system disc in the cd rom.
10/11/2023 4:56:30 PM •
Toshiba...
Answered
on Oct 11, 2023
Toshiba Strata CHSU40A3 no display or tone
If your Toshiba Strata CHSU40A3 phone system is not displaying anything and there is no dial tone, there could be a few reasons for this issue. Here are some troubleshooting steps you can try:
- Check the power source: Make sure the phone system is plugged into a functioning power outlet and the power adapter is working correctly. You may also want to try plugging it into a different outlet to see if that helps.
- Check the connections: Make sure all the cables and cords are connected properly. If the phone is connected to a network, check the network cables as well.
- Reset the phone: Try resetting the phone system by unplugging it from the power source and plugging it back in after a minute. This will help to clear any issues with the phone system.
- Check for any damage: Inspect the phone system for any physical damage, such as cracks or breaks in the casing or any loose components. If you find any damage, the phone system may need to be repaired or replaced.
If none of these troubleshooting steps work, you may need to contact a professional to diagnose and repair the issue with your Toshiba Strata CHSU40A3 phone system.
3/2/2023 5:37:06 PM •
Toshiba...
Answered
on Mar 02, 2023
What happened when Toshiba laptop shows alt+ctrl+del?
More commonly called 'control alt delete' or the 'three finger salute' it has two purposes. On a computer that is running, it brings up Task Manager and other instant settings like Switch User, or log Out. On a computer that is frozen, unresponsive, it does a hard rest and forces the computer to reboot.
2/22/2023 11:34:41 PM •
Toshiba...
Answered
on Feb 22, 2023
My toshiba laptop displays an expected error occured. Error Code 0xc0000034 during booting window
This error code 0xc0000034 usually indicates a problem with the boot configuration data (BCD) file on your Toshiba laptop.
The BCD file stores boot configuration information and is required for Windows to start up. The most common cause of this error is a missing or corrupt BCD file.
You can try the following steps and can try to resolve this issue:
1. Boot into the Windows Recovery Environment (WinRE)
2. Launch the Command Prompt.
3. Type the following command to rebuild the BCD file: "bootrec /rebuildbcd".
4. Press Enter and follow the on-screen instructions.
Note: If these mentioned steps do not resolve the issue, you may need to perform a repair install or a clean install of Windows.
2/3/2023 11:39:14 PM •
Toshiba...
Answered
on Feb 03, 2023
