Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty . Please use volt meter to test correct voltage and ohm feas ng on speakers.
.A thumbs up would be greatly appreciated if this answer is helpful to you.
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty. Good L
MTX Audio
sounds like you may have a bad torroid (the donut looking thing). you may also have a bad ground connection. make sure you have completely bare metal where the ground connection is. you need a very clean connection.
THIS LINK WILL TAKE YOU TO THE SUPPORT PAGE FOR THE 1000XD. IF YOU WERE REFERRING TO THE SERVICE MANUAL OR SCHEMATIC OF THE CIRCUIT BOARD, THEN YOU WILL HAVE TO CONTACT MITEK AT 800-225-5689 AND ASK FOR MR. DABBAS. LET ME KNOW IF YOU REQUIRE FURTHER ASSISTANCE......V
The light flashing usually means there is a short somewhere. Check your wires to make sure there are no slices and are touching. Also check to make sure you have your remote wire hooked up.
It sounds like you may have a ground loop issue. I'd start by checking all the power and ground connections. Then disconnect the RCA wires from the amplifier. If the hum goes away then you should try grounding the stereo to a better grounding point, the factory grounds are usually not very good at all. Then try it again, if it is still there try replacing the RCA"s.
If the hum is still there after you've redone the connections and replaced the RCA's, you may need to install a ground loop isolator.
Both www.crutchfield.com and www.sonicelectronix.com sell good ones.
I was having a similar issue. I checked every wire from the battery to stereo to amp, checked the ground, pulled the stereo to double check the wiring was all correct. Everything seemed good so I thought it had to be my battery not putting out enough power. Tested it and it was good. What it turned out to be was the connection from the power cord to the battery. It had a tiny bit of built up corrosion that was making the amp go into protect mode. Cleaned it up and hooked it back up and has been golden since. The link attached is pretty straight up on what you need to check for different circumstances. I'm guessing it's a low voltage issue. Good luck
