20 Most Recent
Garmin nuvi 885T GPS Receiver Questions & Answers
Remote does not work 885t
plug the garmin into the compuer
naviate to the drive
find the ASR folder
delete all languages you don't want
check the voice folder, clean it up too
go into gpx and delete the Archive (bread crumb trail) folder
run the update again and make sure to choose USA and CANADA. both must be on there for the voice command to work.
My garmin nuvi50 not conect with the computer
Does the unit boot properly to the main menu? The subroutine that scans for a PC to GPS data connection only can occur at the main screen. Does the USB port appear to be loose? bad connection at the USB port will prevent the PC from linking up to the Nuvi.
Screen Acts likes its locked
Question:
My nuvi 850, 855,
860, 865, 880, or 885 is freezing up or will not boot up past the
Loading Maps screen.....
Answer:
If your nuvi 850, 855, 860, 865, 880, or 885 is
experiencing any of the following symptoms:
- The touch screen
is no longer responsive and the unit appears to be locked up
- The
unit will turn on however freeze at the point where it indicates that
it is Loading Maps...
- The unit takes five minutes or longer to
be recognized by your computer as a mass storage device
A
software update is now available for you to update your nuvi to correct
these issues. Please use our
WebUpdater
program to install this update.
Please note: Due to this
problem, it may take up to five minutes before your computer will
recognize your nuvi as a mass storage device. This software update will
correct this issue as well.
//changed this line from 'solution1description.innerHTML' to use getElementById
//to prevent FF warnings. They both appeared to work, but this is cleaner.
solution = document.getElementById('solution1description').innerHTML;
Last modified on:
12/21/2009
I'm trying to update my
Here is a link to Garmins web updater, you always need the most current version of the web updater on your computer. Click the link or copy and paste it into your web browser it will take you there. There are full instructions on how to install the web updater on the site.
http://www8.garmin.com/products/webupdater/howtoinstall.jsp
I hope this helps you out if it does please leave me a Yes that you were helped. Thank you.
How do I reset my
This procedure has been known to (but doesn't
always) delete your favorites so back them up beforehand: From the nuvi
drive, copy x:/Garmin/GPX/current.gpx to your backup location. After the
hard reset, copy current.gpx back to the same folder on the nuvi but
rename it temp.gpx (important). On the next power cycle, the favorites
will be read from temp.gpx into the non-user accessible memory area on
the nuvi where they are actually stored (current.gpx is only a shadowed
backup of your favorites)
Power the unit off. Press and hold (and continue to hold) the
bottom-right corner of the screen while powering the unit on. Continue
to hold the screen until the "Do you want to erase all user data?"
prompt appears. Press "yes" and the unit will reboot. Reset all your
location settings and user preferences.
If possible after the hard reset, let the unit sit outdoors in the open
for about 30 minutes or so to let the unit re-acquire the satellite
almanac data.
How do I hook up
There isn't an easy way to do this since there are not readily available video inputs on the 885T. Garmin sold a part called a VIB 10 that would connect the 885T and allow a video input. Unfortunately, like the 885T the VIB 10 is discontinued by Garmin. Sorry.
My new garmin nuvi 265W
Have your Nuvi fully charged before you do anything with it
With the unit Off
connect the gps to your computer using the USB cord, your computer will detect new hardware USB port
go to
www.MyGarmin.com once there it too will detect your model and give you the correct updates and unlock maps
you must register your unit with garmin
I have the nüvi 885T.
Have you selected the right language under Tools-Settings-Language........the voice personality, is the one that eeds to be on the right setting. Select a voice that speaks street names to listen to text messages and for voice prompts.
The touch screen on my Garmin is not working. Is
From what I have heard from Garmin, one sends it in along with $90 to get a refurbished unit. LOTS of people are seeing this issue, including myself the other day after only 2 years of using it. I wont be buying another Garmin Product at this point. Seems to be a known issue. Things used to last for decades - now one is lucky to get 2 years out of my things, including Canon and HP Printers! (more experience with that too!)
No voice. Volume bar shows 100% the bar is not
I assume you checked that the mute box is not ticked. If not check it at the same place as the volume. The most likely cause is that there is no voice selected. To select a voice, press Tools, then Settings, then Language, and then Voice. If a voice is not ticked then press one to select it.
It's possible that the voice files have been corrupted and will not work. IF this is the case connect your satnav to your computer and it should automatically download the latest version of webupdater from the garmin website. When updated you will have the option to download voices. Select the ones you want and follow the prompts and they will be downloaded to your satnav. You may then have to to repeat the voice selection process described in paragraph 1 above
The volume is not loud enough, how can you
Touching the screen along the lower left on most gps systems will bring up the volume. otherwise you can use the preferences menu to change them. if the soudn is up all the way then there is nothgin further you can do
