20 Most Recent Vizio VU42L 42 in. LCD TV Questions & Answers
Where is the main board located
Inside the back cover.
3/13/2015 3:06:25 AM • Vizio VU42L 42... • Answered on Mar 13, 2015
2answers
Vizio 42" lcd powers up with sound only - no picture
It sounds to me that the unit has a faulty inverter board which could be due to an overheated/bulged capacitor. I would send in a claim on it to the factory if it is still under warranty.
10/27/2013 10:21:36 AM • Vizio VU42L 42... • Answered on Oct 27, 2013
3answers
Lost screws for stand on Vizio VU42L
If you pay for shipping I will send you my screws. Maybe a buck or two will cover it in an envelope. I just removed them last night as the TV is being junked for the parts. Email me.
MBSimonds AT aol DOT com
7/10/2013 6:23:58 PM • Vizio VU42L 42... • Answered on Jul 10, 2013
Watch my video and help me diagnose my TVs problem...
cable might not be compatible with the TV. try another wire or use regular video cables. see if you can change channel to 3 or 4 for input? I bet the computer might send a signal that makes the tv flutter like that.
5/18/2013 10:41:16 PM • Vizio VU42L 42... • Answered on May 18, 2013
I have a Vizio VF550XVT1A. The screen started to
Hi Alfred Grace,First of all, thank you for posting your question here at Fixya.Based on the symptoms you've described, I don't believe that the backlights are already faulty. If backlights gone to malfunction, that are permanent, but in your case you've said that the TV power up fine for half an hour, this is an indication that the fault not came from the backlights but from the inverter boards. Inverter boards are the one giving high voltage to the backlight to light up, it has a built in protection circuit that will activate once there's a malfunction on the board to avoid further damaged because of high voltage output.If you would like to fix it yourself, I would advice you to replace both the slave and master inverter board. I saw your board at shopjimmy.com. Click it HERE for the replacement. Replacing these boards are not technical, all you have to do is to unplug the unit overnight to drain any voltages from the power supply board, disconnect all connectors and then put-in the new boards. No soldering required. If just in case that the inverter boards are not the issue (I'm pretty confident that the power supply board is working fine), don't worry, the link I've provided accepted return, the fault is on the power supply board.Hope I helped you.Have a nice day!Good luck and take care!Jdvillanueva
2/15/2012 12:30:11 AM • Vizio VU42L 42... • Answered on Feb 15, 2012
I have a large spot
Not possible.Tv have damages to it LCD screen panel by an object or a person have causes by forced or putting pressure to the tv LCD screen panel itself to causing colors picture pixels and it radiation to died to causing this problems.Sorry it time to buy a new tv,because by replacing the tv LCD screen panel itself will cost u the same as a new tv.Tries buy a new tv from the VIZIO tv corporation directly return the damages LCD panel tv to them,u could get a 5 or 10% off of the tv prices.
6/5/2011 10:29:58 PM • Vizio VU42L 42... • Answered on Jun 05, 2011
Vizio VU412L 42" made a
The pop has been generated by the explosion (literally) of an capacitor from the power board of the tv. When that happened the power source has been shorted and, if you're lucky, it went in protected mode. Fixing that is a relatively simple job - all you need is a soldering iron and a basic experience in using it. Follow this
http://www.youtube.com/watch?v=YCSNWi3UHf4
If you're unlucky the entire source has been fried and it will have to be replaced - here's a good one
http://cgi.ebay.com/VIZIO-VU42L-FHDTV10A-POWER-SUPPLY-DPS-283BP-C-REV-S0-F-/370477438027
3/6/2011 2:05:14 PM • Vizio VU42L 42... • Answered on Mar 06, 2011
The tv will not power up. I have power to the
Any time a TV has no power is your power supply that needs to be replace. Check for blownen caps.
Thank you
2/21/2011 1:11:08 AM • Vizio VU42L 42... • Answered on Feb 21, 2011
Vizio VU42L 42 in. LCD TV Logo
56 questions posted
Top Vizio Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Vizio Televison & Video
Most Popular Question
vizio vu42l
  • Televison & Video
