20 Most Recent
Sanyo DP26648-R 26 in. LCD TV Questions & Answers
2008 sanyo lcd tv DP26648 power turns on but no picture or sound
likely a mainboard or power supply capacitor issue.
if you have the soldering skills fix it, otherwise time to replace the TV.
If you can de-solder and solder in new capacitors make sure you are using high quality capacitors be very causious of capacitors purchased from auction sites.
Power light comes on but no picture or sound
many tvs were plagued by bad capcitors on the main board and/or power supply.
if you are comfortable with soldering go for replacing the capacitors. if not it is not worth having repaired, cheaper to replace the tv.
I last the tv remote model dp26648 i want remote
Setup codes to check with Sanyo brands are
004/ 013. If you wish to get more details about four digit and five digit codes, check this link. There is setup code list to many brands of remote controls. Just see and check which brand has setup code to Sanyo. It will make you remote selection easy. There is an other link. Check this too.
Blue and pink dots displayed on screen
Looks like the display has developed some problem. Try changing the input device to some other like a DVD player, VCR etc. If the problem persists, this might require attention by a qualified service technician.
Neither "solution" is a solution. Anyone actually
Your problem is the T-con board. This is gone bad/faulty. I would advice you to replace it with new T-con board and your unit will back to normal again. You may look for the replacement online. Try ebay.com or shopjimmy.com.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Tv is not responding to the remote
Look on the side/back of the set for the control buttons. Try them. If they work, then you can do a quick check of the remote by;
Get a digital camera (turn on) and point the remote at the lenses.
If you see a flash on the lcd display, the remote is giving a signal and the problem is probably in the remote sensor on the set.
If you do not see a flash the remote may need new batteries.
No camera? check the batteries anyway.
Trying to hook up my ps3
ok i have come acrost this problem with my ps3
turn the ps3 off plug all the cables in right and put the tv on the right video input now hold down the power button on the ps3 for about 30 - 60 secs or untill it beeps or you see it working
let me know if it works
PLEASE RATE thanks
