20 Most Recent
Samsung HL61A650 TV Questions & Answers
My tv won't turn on.
Yes,if the tv LED light indication the word "LAMP" on the tv bazel frame is lighting up or blinking.The tv old projection lamp been inside the tv like 1 1/2 or 2 years,tv been on and used daily 4 or 5 everydays?Yes,than ur tv projection lamp life are ended.Yes,than ur tv need a new projection lamp.
Samsung dlp hl61a650c1fxza turned off
Hey dsfrank6088, i have the same issue right now. I called tech support and they are telling me that i need to change the light bulb which i did less than 3 months ago. Please let me know if you did find a solution!!
Volume/sound will not increase up
If the volume indicator appears and respond as you increase the volume but the sound does not respond, there might be a problem on the audio section.Ask for a repairman to check it. If the indicator does not respond, try using manual control instead of using remote control.Also some units have features to turn speaker off or on. Go to menu scan for audio check if it is turned off or on.
My samsung is turning off
Please elaborate / explain here a bit more. You hit any button on the drectv remote and it turns off the TV? Do you have the original remote, and does that operate just fine?!
Let me know thanks
Tim
I have a samsung hl61a650c1fxza
I had the same problem and had a repair guy fix the problem today. Needed a new power supply, ballast and lamp. My TV is now working so this is something you might look into.
Turns on and of f by it self every 15 seconds
You need to call Samsung about it and tell them your Model number. I
have the same problem and they say that they don't have this problem
with this model only with the LCDs. I have a
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
HL61A65 it only started going thru this cycle right at 2 years. Out of warranty of course. We need more calls to them so they will pay the repair to fix the problem. I called 1800-726-7864
