20 Most Recent
Polaroid TDX-02610B LCD TV Questions & Answers
How do I remove the dvd player?
your not being clear if its a laptop PC or other, PC are 4 screws and in some cases a catch somewhere, maybe the front of the PC case comes off so the DVD unit can slide out the front, Laptops are normaly 1-2 screws under the laptop with in about 4-5 inches area of the DVD unit.
11/17/2013 10:12:53 AM •
Polaroid...
Answered
on Nov 17, 2013
Polaroid TDX02610B
Black screen but audio works
Problem is in either power supply or the Y-Sustain board.
The Y-Sustain is a relatively large board out of which go connections to the side of the display; it's therefore closer to either the left or the right side of the display, has at least one rather large heat sink on it and fat power cables connecting it to the main power supply.
Often there are fuses on that board - one or more.
if they are blown you can try to replace them, but expect them to blow again - usually the whole board needs to be replaced.
Take care in handling the set.....
8/8/2011 7:55:19 AM •
Polaroid...
Answered
on Aug 08, 2011
Polaroid TDX-02610B, Tv was working fine, turned
If it is only the screen going black but the TV remains on and you can hear audio, then there is a problem with the backlight. It could be due to bad capacitors or it could be a faulty inverter. It requires repair by a competent engineer.
3/7/2011 9:33:50 PM •
Polaroid...
Answered
on Mar 07, 2011
Intermittent black box in the middle of the screen
that could be that the back light is on it's way out but if you turn it on from cold and the screen takes a bit to come on then don't worry as it could take a while longer before needs replacing
11/27/2010 11:44:20 PM •
Polaroid...
Answered
on Nov 27, 2010
