20 Most Recent
LG Electronics 42 in. LCD Tv Questions & Answers
42 inch LG LCD tv, mounted over a radiator?
electronics do not like heat and and heater works by rising hot air
in your case that hot air will go straight up into the electronics which will result in problems
a wide shelf under the tv will be a good idea as that will stop excess hot air straight up into the tv
The picture is fine but the voice is not working
Sound issues and answersa short list:sound on set or a box muted or turned down?
speakers inside the set (see menu) switchedon or off?internal/external switch somewhere in or on back of set?Clearly it could be a audio problem (a model number?) but explore all here thatyou have not already done--make sure theremote set to TV and look for a button on it marked MTS and if there cycle it.You can also determine if same trouble when you play a DVD.
How do i clean the screen
Tries websites like Amazon.com,Ebay.com to buy a pack of cloth.They are called Mircro Fibers clothes.They're are the best and the safest product to used because they are made out of silkworm cacoon materials.The best materials for to used like shinning jewleries,eye glasses and electronics screen panels surfaces.Just add some water only no chemicals and very gently press against the tv LCD screen panel slowly vertically or horizontally clean the tv screen panel.
I have LG 32LC2RR
hello and I got the same problem and solve it as I put a small hard drive HITACHI 40 GB. then your TV formats it alone. I put the disc in its original computer and deleted a partition, then created a new fat32 partition and format the drive with partition Magic.
. after being assured that no disk errors and put the second disc on my computer. I used norton ghost and clone HITACHI seagate disc on the disc. never mind one that is less than the other. importantly, the small disc was recorded right information and transfer it to large.
in the whole thing was a big obstacle. after its original disk formatted TV stopped initialize it strange is because of the Hitachi drive was installed Linux and TV recognized it without problems and I formatted it alone. may have been lucky not know.
Popped and we lost picture. sound still on
Checck within for visible signs of a capacitor burst in the invertor section or the convergence section or the driver.
If it is detectable then you can remove and replace with the correct rating.
My 1 year old son hit my 42 inch with a remote
Cost same as a new tv,to replaced the LCD screen.There are hundred or more sell for parts because Broken LCD screen sell in Ebay.com.The TVS industries well not sell out LCD Screen cheap or resonable price.
