20 Most Recent Initial HDTV-320 32 in. LCD TV Questions & Answers
The sound keeps going on and off.
Hi Gregory, Defective speakers often behave in this manner. Please have them checked.
1/13/2016 4:24:48 PM • Initial HDTV-320... • Answered on Jan 13, 2016
Need remote codes for INITIAL flat screen tv
028,029,0291,0285. Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name" in alphabetical order. Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box. http://electronicshelponline.blogspot.com/ http://remotesearch.blogspot.com/ http://electro-medical.blogspot.com/ http://electrohelponline.blogspot.com/ 25395427-wf2qvkllbkbddj20oueqc1az-3-0.jpg
2/2/2015 1:17:15 PM • Initial HDTV-320... • Answered on Feb 02, 2015
What can make the screen go black on a Initial HDTV-320, there is no prolbem with the sound?
It is usually the sustain driver board that powers video. I'm looking for one now for my Samsung. Best thing to do is replace it if you can find one on eBay. They are easy to replace. You will need your old board part number and model of TV, use only the exact matching board part# or you may create a fire or electrical hazard. Always wear gloves, capacitors hold voltage for a couple of days. If bare skin touches one that still has a charge you will know it. I’m happy to help further over the phone at https://www.6ya.com/expert/david_c087e4b7d13c0163
5/24/2014 8:24:36 PM • Initial HDTV-320... • Answered on May 24, 2014
No signal for HDMI or DVI
Hi, what device or devices have you tried to connect through those ports? Were they working prior to this problem?
3/29/2014 3:08:49 AM • Initial HDTV-320... • Answered on Mar 29, 2014
0answers
0answers
DVD Stuck
Be the first to answer 10/7/2013 1:54:39 AM • Initial HDTV-320... • Posted on Oct 07, 2013Be the first to answer
Snow on screen but menu appears ok
how to solve agc voltage
9/26/2013 6:16:47 AM • Initial HDTV-320... • Answered on Sep 26, 2013
How do i put it to play dvd player
  • Turn off and unplug the HDTV set and the DVD player before attempting to connect component cables to them.
  • 2
    Match the red, green and blue colored cables to each of the color-coded counterparts on the back of the DVD player. Be sure the cables are being plugged into the TV-out section of the DVD player.
  • Plug the other end of the color coded cables into the HDTV set. There should only be a red, green and blue cable being plugged into the TV. It does not matter what input these cables are plugged in, but keep track of which particular one it is. Most HDTV sets will have more than one A/V input, which is why it's important to take note of where the component cables are located.
  • 4
    Power on the DVD player and the HDTV set. If not already plugged in, ensure both of these are properly plugged into an outlet.
  • 5
    Press the "Source" button using the HDTV remote and locate the input channel that has the component cables plugged into it. The HDTV set should now show the DVD player logo or an introduction to the DVD.
    Car Tuning
  • 5/24/2012 9:41:11 AM • Initial HDTV-320... • Answered on May 24, 2012
    0answers
    Recently moved to another city,
    Hi my nameis Mike Houston of DISH Network and I was going over your post and see youmoved and lost the remote. We have what we call a Power Scan for the DISHNetwork remote; it will allow you to get the code to the TV. http://www.dishnetwork.com/SupportSection/power-scan-instructions
    5/9/2011 7:22:13 PM • Initial HDTV-320... • Answered on May 09, 2011
    Codes for universal remote control
    May I get the model # of the universal remote control
    1/12/2011 5:36:37 AM • Initial HDTV-320... • Answered on Jan 12, 2011
    The tv turns off on
    hi,
    possibly sounds like a heat dissipation issue.(dusty ) could try a small fan pointed towards the back of the set untill you can get it serviced. if not then most likely the light source is going out. either way its going to have to be serviced soon. you could try and take it apart and dust it out with an air compressor if your mechanically inclined, google the name brand for disassembly instructions and light parts LCD's have a flourescent bulb in them. if you can get it out rather than having to take the whole set in, you just saved youself a you know what load of money!
    jm
    jm
    1/3/2011 7:39:06 AM • Initial HDTV-320... • Answered on Jan 03, 2011
    EN DONDE PUEDO CONSEGUIR LA FUENTE DE LA INITIAL
    Caps bulged in power supply
    12/6/2010 4:04:26 AM • Initial HDTV-320... • Answered on Dec 06, 2010
    Volume is stuck, buttons on tv wont lower it and
    Sometime if a button is stuck it can lock up the processor and cause all the buttons connected to it to not function. Insure all buttons press and release normally. If all buttons appear to press and release in a normal fashion a trip to the repair center may be call for.
    7/3/2010 4:37:39 PM • Initial HDTV-320... • Answered on Jul 03, 2010
    Initial HDTV-320 32 in. LCD TV Logo
    36 questions posted
    Top Initial Televison & Video Experts
    Grand Canyon Tech
    Grand Canyon Tech
    Are you an Initial Televison and Video Expert? Answer questions, earn points and help others
    View Most Popular
    • Initial Televison & Video
    Most Popular Question
    make screen go black initial hdtv 320
    • Televison & Video
