20 Most Recent
Haier HP42BB 42 in. Plasma TV Questions & Answers
I have no sound in my haier plasma tv
Something to do is does set have sound on any input (like a dvd player connected to a rear input?Also in the setup or audio menu are the speakers switched to OFF?
Need a main or ssb module
Tries websites like Shopjimmy.com,Ebay.com for searches.They have huge inventory of refurbish boards for LCD,Plasma tvs.
Menu Scrolls Uncontrollably
The most common cause of the problem is a stuck/shorted button
either on the television or on the remote. The worst case scenario is a faulty key control board. Remove the remote control
battery or put it away from the television. Press the menu button on
the television and check if the menu scrolls by itself. If yes, the
DOWN button is stuck or shorted. You can actually hear or feel it click when pressed if it is not stuck.
Open the back of the television to gain access to the key control board. You can either repair/replace the faulty button or replace the key control board. Remove the screw holding it to the television casing. Disconnect the old board and install the new one.
Replace the remote control if the buttons on the television control are working properly.
Dead, No click, No LED, Nothing.
I was having the same problem and i called haier co. to ask what i could do and they said to order a new remote control so i did and i received it and i turned my tv with the new remote and pushed the tv/use button and finally worked thank god. i wasn't getting any response at all only blue screen.and no signal. maybe you could try it remote only 20.00.
Watched dvd now cannot get back to cable tried
If all the other functions work on the tv remote, then turn the tv off, then un-plug it for 10 minutes. Plug it back in and turn it on. If the input button still doesn't work then go into the tv menu and try and change it there. Let me know how it turns out?
Nothing works
i had exactly the same problem but not anymore. i called the haier co. and they told me to order a new remote control so i did. i got my new remote and i turned my tv on and pushed the tv/use and it worked thank god. so maybe you could try it. remote control only 20.00 good luck!
