20 Most Recent
Hitachi L32H01 32 in. HD-Ready LCD TV Questions & Answers
I have a L32A01 TV.
change the electrolytic caps on the power supply board use 105 degree and higher voltage working caps if you can fit them on the board its a common problem the power supply is the overworked part of most tv,s etc
HOW to view sky tv on ..
Hi.
Connect skybox using scartlead, or if you have HD use HDMI lead connection..
Select connection by using the AV (alternate video input) on your remote control--this will switch from freeview to sky.
Happy viewing.
Standby light sometimes comes on. When on and
This tv problems u have are only can be causes by only two boards 90% lightly it is the tv power supply board.5% it could be the tv Tuner signal board.5% could be both boards are dead require changes both boards.The tv power supply board it is the board that where the tv power a/c cord plug into it.The tv Tuner signal board it is the board that where the incomming broadcasting signal cable wire plug into it.Tries websites like Shopjimmy.com,Ebay.com to by a whole refurbishes power supply board or tv Tuner signal board or both.
How to turn off speakers L32HO1U
It will if the set has this be in the setup or audio menu, access with the remote and start looking, a owner manual would be real helpful.
Hitachi L32H01 32" TV Power issue
You might need to try to get the schematic and verify all the voltages--note in this kind of situation you need to measure each exactly at turn on in case one is going low or off quickly.The other thing you can do on the larger voltage lines (above say 12vdc) is with the set unplugged check resistance to ground on the chassis and look for any very low resistance readings--i.e. a dead short to ground.Other than this it becomes a game of guess, buy a board and try a board which always leaves the possible result of the panel causing this.Good hunting and if you have questions let me know.
Does not turn on
Hi, Try another plug in the place. If that doesn't work you will need a new power board. Have it checked at a tecky place. Good luck.
When I turn on the
It is a bad power supply for the backlight. That is the only section capable of such a noise. Good luck i hope this helps. I know i have heard similar sound from a laptop with similar issues! Prodzilla
Hi dear
my hitachi L32h01
Hello, Looks like a power supply, causing power outages. Do you have the technical ability to carry out the inspection or replacement
