20 Most Recent Hannspree HT09 28 in. LCD TV Questions & Answers
0answers
0answers
Screen goes red then green then blue
Sounds like a T'Con board fault. If you're sound in electronics, and wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Flip card, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.
11/1/2013 2:01:16 PM • Hannspree HT09... • Answered on Nov 01, 2013
V chip
To release V-Chip code, you have to enter its service mode. Check this link. http://electronicshelponline.blogspot.com/ Pull up previous posts there, either by its left side bar, or view it in Timeslide option. It has details about how to enter, adjust and exit service mode, to many brand TVs.
7/4/2013 4:48:40 PM • Hannspree HT09... • Answered on Jul 04, 2013
2answers
Can't get my hannspree remote to work with comcast
10030 for the comcast dvr remote. Code is from NEC
7/4/2013 1:20:57 PM • Hannspree HT09... • Answered on Jul 04, 2013
Hannspree 28" tv video shuts off after on for a few minutes
It sounds that the fault is with the connections that goes to panel from its T'Con board. Check all the flat cable connections. Re-seat them once.
1/12/2013 3:41:33 PM • Hannspree HT09... • Answered on Jan 12, 2013
Atualizacoes hannspree ST251MAB
What is the problem you faces with this TV? Provide more details please.
9/14/2012 10:55:06 AM • Hannspree HT09... • Answered on Sep 14, 2012
Hdmi1 has no signal
Use HDMI 2. This T.V. is unlikely to have replacement parts because it is not a mainstream TV. (Samsung, Panasonic, etc..) Make sure your HDMI cable is good too and your cable box or what ever other device you're using is properly connected and on.
6/19/2011 7:32:41 PM • Hannspree HT09... • Answered on Jun 19, 2011
Trying to program Dish Network remote
Hello, this is a simple issue to fix!!!! follow these simple steps from our website, and that remote will be working right away!!!!! Now, to program your remote to the TV, you will want steps 6 and beyond. And all steps 1-5 are for programming the remote to the receiver. Hope this helps!!!!!!!!!!!
http://www.dishnetwork.com/SupportSection/remote-setup
Becki Barned
DISH Network Customer Service
1/16/2011 1:18:37 AM • Hannspree HT09... • Answered on Jan 16, 2011
Got sound but no picture LCD is not even lighting
If an LCD TV has sound but no picture do the following:
Use the source button to ensure that source is not set to the wrong input.
Try unplugging power cord for ten minutes, to ensure it is not a setting problem.
Check all the video cables at the back of TV.
Check Light /Color settings.
If problem persist and does not depend on external receiver or settings, then it is likely an internal fault.
If it has sound but no picture then one of the following parts is faulty, and must be tested and replaced:
The inverter is the high voltage board that provides variable power to the backlight lamp. This is the most common. When inverter is faulty you can get no picture, or a very dim picture that can only be seen by pointing a torch light with a 45 degree angle on the LCD surface from very near distance.
The inverter must be tested by reading voltages with a multimeter.
The LCD ribbon cable/LCD display and connectors.
This is quite uncommon, but happens. If the TV had been hit or moved the LCD cable may have slipped out, or the LCD connector may be damaged.
The LCD controller board.
This is the board that controls the video signal, it is difficult to test, as there is need to read determined values on IC pins. To test this board you need to purchase a service manual and follow the troubleshooting diagrams on service manual.
Input/Output Signal boards.
This are the boards where you connect the video and audio cables, if a signal board is defective, then you may get no picture on particular inputs located on faulty board.
If under warranty contact the manufacturer ringing the number on the user manual.
If you want to repair at your own expenses, just locate any good qualified repairer.
1/11/2011 12:10:27 PM • Hannspree HT09... • Answered on Jan 11, 2011
Code needed for Sony rm ez4t remote control
Buy a learnable remote.
1/1/2011 7:15:07 PM • Hannspree HT09... • Answered on Jan 01, 2011
Wont turn on power is going to tv blue light wont
Check the power suply caps and backlight inverter for shorts, please read below to understand how the LCD TV works.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx
8/9/2010 12:00:42 AM • Hannspree HT09... • Answered on Aug 09, 2010
I broke the screen on my 32 inch hannswing. is it
The cost would be prohibitive if you could even find one. Possibly one from Craigslist that is not working but good screen, otherwise throw it away or sell for parts. New ones are too cheap to try and repair that component.
12/28/2009 3:59:17 PM • Hannspree HT09... • Answered on Dec 28, 2009
TV doesn't receive signal
Faulty Video boards If you bought it in May then rapidly get it fixed under warranty or exchange it for a better brand. Who is Hannspree? not well known and may be cheap Korean TV with no parts available
Please rate our help to keep FREE service online++++Thanks for using FIXYA
9/12/2009 4:30:56 PM • Hannspree HT09... • Answered on Sep 12, 2009
Hannspree HSG1074 LCD HDTV
The weight of the Hannspree HSG1074 24 inch LCD HDTV is approximately 8.8 pounds (4 kg) without the stand. However, the weight may vary slightly depending on the specific model and any additional accessories that are included with the TV. If you need more precise information, you may be able to find the weight listed on the product specifications page on the Hannspree website or in the user manual that came with the TV.
4/26/2023 4:59:13 AM • Hannspree... • Answered on Apr 26, 2023
2answers
Hannspree 42 lcd right side is showing ghost picture
The issue you are experiencing with your Hannspree 42 LCD TV could be caused by a few different things, such as a loose cable connection, a faulty T-con board, or a defective panel. Here are a few steps you can try to troubleshoot the issue:
  1. Check the cable connections: Make sure that all the cables connected to your TV, especially the ones connected to the right side of the TV, are firmly plugged in.
  2. Power reset: Try turning off your TV and unplugging it from the power outlet for at least 10-15 minutes, then plug it back in and turn it on again.
  3. Swap inputs: If you are only experiencing the ghosting on one input, try swapping the input with another one to see if the issue persists.
  4. T-con board: If none of the above steps resolve the issue, it is possible that the T-con board is faulty. The T-con board controls the timing of the image displayed on the screen and is often the culprit of ghosting issues. A technician can diagnose and replace this board if necessary.
  5. Panel: If the above steps don't resolve the issue, it is possible that the LCD panel itself is defective. This is less common but can happen over time. Unfortunately, replacing the panel can be costly and may not be worth it on an older TV.
If none of the above steps resolve the issue, it may be best to contact a qualified technician to diagnose and repair the issue.
2/28/2023 1:47:00 PM • Hannspree... • Answered on Feb 28, 2023
How to Program hannspree remote to hannspree tv
To program a Hannspree remote to a Hannspree TV, first turn on the TV and then press and hold the "Code" button on the remote until the LED light turns on. Next, enter the four-digit code for the TV using the number keys on the remote. If the TV turns off, press the "Code" button to save the code. If it doesn't turn off, try another code until you find one that works. If you cannot find the four-digit code for your Hannspree TV, you can try using the code search feature on the remote. To do this, follow the steps for programming the remote but instead of entering a code, press and release the "Code" button and then press the "Power" button repeatedly until the TV turns off. Then, press the "Code" button to save the code. If you are having trouble programming the remote, make sure you are aiming the remote directly at the TV and that you are not too far away. Also, check that the batteries in the remote are fresh and properly installed. If you accidentally program the remote to the wrong TV or if you want to program it to a different TV, you can reset the remote to its default settings by pressing and holding the "Code" button for at least three seconds until the LED light turns off. This will erase any previously programmed codes.
2/14/2023 10:49:36 AM • Hannspree... • Answered on Feb 14, 2023
Hannspree tv screen comes white no picture
Question moved from Cellphones. It is broken, but try a power reset. Disconnect the mains power at the wall outlet for 5 minutes. https://www.fixya.com/support/r29790007-repairing_own_television ..
11/23/2022 7:01:54 AM • Hannspree... • Answered on Nov 23, 2022
Hannspree HT09 28 in. LCD TV Logo
32 questions posted
Top Hannspree Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Hannspree Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Hannspree Televison & Video
Most Popular Question
got sound but no picture lcd not even
  • Televison & Video
